Could not connect to Wifi
This is a discussion on Could not connect to Wifi within the iPad Help forums, part of the Apple iPad Discussions category; Hui, I have an iPad2 and a pldt dsl internet service with a router. My macbook pro can connect wireless to the internet but my ...
Results 1 to 2 of 2
    81708
    Jul 2011
    Hui,
    I have an iPad2 and a pldt dsl internet service with a router. My macbook pro can connect wireless to the internet but my iPad2 could not. What do I do?
    580 times
    Dayton, WA
    13,192
    Does the iPad get a signal and join the network?
    Try turning the router off for about two minutes. While it is off go into your Settings on the iPad, Wi-Fi, choose the network and tell it to forget it.
    After the router is back up try connecting to the network again and see what happens.
    If that does not work give your provider a call. Sometimes they limit the number of IP addresses a router will give out. If so you may need to get them to increase that number, or use an ethernet port out of the router to make your own network with yet another wireless router.
    Good luck.
  1. ipad 2 will not connect to wifi
    By gcclubs in forum iPad 2 Forum
    Last Post: 01-07-2013, 04:26 PM
  2. How to connect to WiFi
    By dave.allen@telus.net in forum iPad Help
    Last Post: 05-27-2011, 11:13 PM
  3. Can't connect wifi
    By gaza111 in forum iPad Help
    Last Post: 05-27-2011, 11:03 PM
  4. Can't connect with full 3G and WIFI
    By willynotwonka in forum iPad 2 Forum
    Last Post: 04-21-2011, 06:41 PM
