I need help
This is a discussion on I need help within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I need help maybe someone out there has gone thru this. As from about 2 months ago whenever I connect my IPad to my ...
I need help
Hi, I need help maybe someone out there has gone thru this. As from about 2 months ago whenever I connect my IPad to my PC, the PC restarts automatically. I was told to uninstall I-Tunes and re-install it which I did but still with the same problem.Please can anyone help as I cannot sync my IPad with my PC anymore.
07-26-2011 11:32 AM
That's strange. Have you talked to Apple support about this?
Aimee
artist, student,mommy, Apple fan, Dachshund lover
"Be excellent to each other"- Bill & Ted
It might be a fault USB port on the PC, have you tried plugging your ipad into a different usb port?
iPad Enthusiast!
Yes, it looks like a USB power issue. More details about your machine, OS, memory... that could help.
Does your Pc restart also when overloaded with sound/music programs? It happened to me a while ago and had to reconfigure some settings. Motherboard was getting in heat.
MAc is now using NASA Visualization Explorer
_________________________
My iPad is got a name: @ntipad
Go into you settings and find where the default action is for when a camera is plugged in. Change that to nothing and see if that helps.
Sorry I can't be more specific about the settings. My only Windows machine is buried, and I'm not brave enough right now to disturb the easily toppled pile of junk.
Please be patient cos I cannot get the hang of things. I have tried another usb port and still same problem. Now which settings do I go into? The computer settings?
Originally Posted by
bestie59
You say that, when you plug your iPad into your PC, it restarts. What happens if you let your PC restart? Does iTunes automatically launch when the PC has completed its restart? If it doesn't, what happens if you manually launch iTunes? Does it 'see' your iPad?
Hi, when I leave it connected to the PC it keeps restarting over and over, even when I tried to launch I-tunes manually
A PC keeps a log of unusual events in the Control Panel. It might be worth looking to see what your PC suggests caused the problem. 'Control Panel', 'Problem Reports and Solutions' and then investigate what Windows says caused the unexpected shutdown.
A PC will reboot if certain voltages drop below a predetermined level which appears to be your case. The USB supplies a voltage to power things like a mouse and keyboard. Depending on your situation you could be over loading the USB with to many devices or the Apple iPad cable is shorting out.
To be on the safe side I recommend you take your iPad and cable into the apple dealer and have him check it for you, then you know what equipment is offending, also you don't want to damage your iPad with a bad USB port.
If you can't make it to the dealer then try plugging another USB device using a completely different cable. If that does not reproduce the problem try plugging your iPad into another computer. Usually I don't test suspect equipment with anything important because the good equipment is now bad or damaged.
Sent from my iPad 32/3G using iPF
- You may not post replies
- You may not edit your posts
Forum Rules
ipad shorting out
is there pc sync to ipad help in lima ohio
my ipad keeps shorting out
