Applications quitting
This is a discussion on Applications quitting within the iPad Help forums, part of the Apple iPad Discussions category; Hi, Since some time I have the ever growing problem that the applications are quitting without any warning and I get back to the Finder. ...
Results 1 to 6 of 6
    12592
    Aug 2010
    28
    Hi,
    Since some time I have the ever growing problem that the applications are quitting without any warning and I get back to the Finder. I had begun writing this message on the iPad, but it was not possible: Safari has quitted several times.
    This problem is it known?
    What may I do?
    iPad 1
    FW 4.2.1
    Best regards
    Aloha
    116 times
    15,249
    12592
    Aug 2010
    28
    Hello Tim,
    Thank You very much.
    The first method was not the solution, but until now it seems that the second one is it.
    Isn't there a newer FW version and is it recommended to upgrade?
    Regards
    Alooha
    576 times
    Dayton, WA
    13,177
    The current iOS version is 4.3.5. If you don't need to jailbreak there is no reason not to upgrade. When you connect it to iTunes and it says an update is available you may want to try the Download only option. It has a better history of successful downloads and trouble free updates.
    12592
    Aug 2010
    28
    Hi,
    I think I don't need that; I connect it to tzhe Internet via my iPhone 3GS.
    As I don't have a SIM card in the iPad it isn't even possible to jailbreak it. Is that right?
    Aloha
    116 times
    15,249
    Whether you have a SIM card in your iPad has no impact on whether or not you can jail break it. You can connect to the Jail break sites using WiFi.
  1. Quitting Skype
    By Broadwinged in forum iPad General Discussions
    Last Post: 05-05-2011, 04:33 PM
  2. Replies: 0
    Last Post: 02-27-2011, 06:10 PM
  3. Applications - Which Ones..??
    By sticky1 in forum iPad General Discussions
    Last Post: 12-05-2010, 06:26 AM
  4. Web Applications for iOS
    By monkey_slap in forum iPad Development
    Last Post: 12-03-2010, 03:22 PM
  5. quitting We Rule - how?
    By CMFox in forum iPad Apps
    Last Post: 08-13-2010, 11:14 AM
apps quiting on ipad
how do you quit an ipad app
how do you quit apps on ipad
ipad programs quit
ipad quits apps
ipad quitting applications
ipad quitting out of aps
programs quit on ipad
quitting apps on ipad
skype quits ipad
why is ipad 1 quitting out of apps
why programs quit without message
