Applications will not open.
This is a discussion on Applications will not open. within the iPad Help forums, part of the Apple iPad Discussions category; I have to first generation ipad wifi 32 GB since October of 2010. None of my applications will open, not even the applications that are ...
Results 1 to 5 of 5
    80915
    Jul 2011
    Florida
    I have to first generation ipad wifi 32 GB since October of 2010. None of my applications will open, not even the applications that are standard for the ipad like email, safari. I noticed I can open apps like calender and notes, so it seems when I connect to the internet the app will close. I also tryed to delete safari's cookies and history and once I hit clear the app will close and not delete the cookies or history.
    I have done a soft restart and that didn't work, I reset my entire Ipad and re downloaded everything and that didn't work. I have also taken it to best buy and they couldn't figure it out.
    Anyone have this problem or know how it can be fixed? If I can't figure out anything I'll jsut bring it to a Apple store.
    Thanks.
    116 times
    15,249
    Time to show the iPad who's boss....
    OK - time for a reboot...
    Turn the iPad off.
    Now press and hold the Home and Power buttons at the same time for perhaps as long as 20 seconds until the white Apple logo appears. Have faith - it will appear eventually.
    The iPad will reboot - this takes some time too.
    Have another look to see if the problem is fixed...
    80915
    Jul 2011
    Florida
    I have tried this multiple times and it doesn't help.
    I can't seem to find anything about it on google either.
    80915
    Jul 2011
    Florida
    Anyone else having this problem. I need help!
    577 times
    Dayton, WA
    13,177
    Quote Originally Posted by atiminsky
    Sounds like you've done a Restore in iTunes. If so I'd consider taking it to Apple. If that is not an option go to the hacking area and look into DFU mode. You may have to force a complete reloading of the firmware. Don't take my word for it though. Read up on it before you try. I don't know much about DFU mode; why and how to use it. I wouldn't have said anything, except the experts apparentlly haven't stumbled across your thread.
    But just to make sure you've done a propper reset, I'll post the instructions for that below.
  1. Replies: 10
    Last Post: 01-16-2012, 02:19 AM
  2. Replies: 3
    Last Post: 07-02-2011, 03:36 PM
  3. Replies: 2
    Last Post: 05-18-2011, 07:55 PM
  4. Open applications help
    By Munchkin52 in forum iPad General Discussions
    Last Post: 04-12-2011, 09:50 PM
  5. MUST HAVE applications
    By kynduvme in forum iPad General Discussions
    Last Post: 09-15-2010, 03:44 AM
app store will not open on ipad
app will not open
applications do not open on ipad
ipad app will not open
ipad applications will not open
ipad apps not opening
ipad apps will not open
ipad will not open app store
ipad will not open apps
my apps will not open
my ipad will not open
reasons why applications in ipad doesnt want to open
