Not charging
This is a discussion on Not charging within the iPad Help forums, part of the Apple iPad Discussions category; No matter what I use to charge my iPad, I get a message in the top right hand corner saying 'not charging' even though it ...
Results 1 to 5 of 5
Thread: Not charging
    80673
    Jul 2011
    Eastbourne
    Not charging
    No matter what I use to charge my iPad, I get a message in the top right hand corner saying 'not charging' even though it is actually charging and shows the percentage when unplugged. Is there anything I can do about this as it may be a problem when it actually isn't charging?
    37823
    477 times
    Cranbrook, Kent, UK
    15,230
    If you are charging via a USB to a PC/Mac you will get the no charging message but it is actually trickle charging. If you are charging from the mains adaptor and it says not charging then there is something wrong......maybe you can be a bit more specific about this?
    iPad Enthusiast!
    60518
    May 2011
    BarcelonAires
    74
    Well, I never had this problem, but logical flow says:
    I assume that you are using the iPad own charger.
    Then some corruption may have happened to battery settings.
    You can hard reset your idevice pressing both the sleep and the home buttons at the same time for 10 seconds. Proceed to fully charge for a couple hours and then open your iPad normally. Let the battery go down using it until let's say 10% and charge again. Let's hope is already showing the right measuraments.
    _________________________
    My iPad is got a name:
    @ntipad
    80673
    Jul 2011
    Eastbourne
    Big Sorry!
    Thank you for taking the trouble to answer guys - made a big booboo - thought Kindle charger was ipad charger - DOH!!!!!
    iPad Enthusiast!
    60518
    May 2011
    BarcelonAires
    74
    Quote Originally Posted by Munki View Post
    Good for you.
    I haven't seen a Kindle wall charger but I assume is different shaped than your standard iPad charger. Still it was performing some charge. Guess it has less USB power draw.
    Mac not downloading anything
    My iPad is got a name: @ntipad
  1. Replies: 7
  2. USB Charging
    By Grandad in forum iPad General Discussions
    Last Post: 03-10-2011, 06:18 PM
  3. Charging on the Go.
    By MuchoiPad in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-21-2011, 12:12 AM
  4. Charging
    By cyprus203 in forum iPad Help
    Last Post: 12-29-2010, 02:16 PM
  5. Charging
    By Aldo in forum iPad Help
    Last Post: 12-26-2010, 02:42 PM
ipad 2 not recognizing usb charger
ipad charging but showing not charging message
ipad not charging
ipad not charging no matter what
ipad not charging right
ipad not recognizing usb charge
ipad says not charge in top right hand corner
ipad says not chargeing in top right corner
my ipad says not charging..how do i get it to charge again?
new ipad showing not charging to pc
says not charging
wahats wrong with i pad not charge
