No audio!!
This is a discussion on No audio!! within the iPad Help forums, part of the Apple iPad Discussions category; I am unable to get sound on music or speech. A small grey patch appears on the middle of the screen with waves emerging from ...
Results 1 to 10 of 13
Thread: No audio!!
    80534
    Jul 2011
    Wellington,New Zealand
    10
    No audio!!
    I am unable to get sound on music or speech. A small grey patch appears on the middle of the screen with waves emerging from it. This appears to be part of the problem.
    13576
    1446 times
    Aug 2010
    Western NY state (USA)
    11,053
    Hello and welcome to the forums.
    Sounds as if you may have your volume muted. Have you, by chance, got your mute switch toggled? It's on the upper right hand side (with the Home button down). Try moving that to the opposite direction...
    If that doesn't do anything, double click on the Home button and swipe to the right. A speaker-like control ought to appear. It may have a line through it - tap it to remove the line. Or, move the bar/circle next to that icon to increase the sound.
    Any of that help? If not, let us know and we'll work more to get you sorted out.
    80534
    Jul 2011
    10
    Still no success
    When I slide the toggle switch a line appears very briefly and then disappears. (2)when I go to the bar/circle you refer to there is a padlock symbol . With the padlock not locked I slide the audio bar/circle and a brief sound is heard and the bar/circle slides automatically back. (please continue to advise me!!!
    80534
    Jul 2011
    10
    Did you get my reply to your first message of advice?
    119 times
    15,248
    Did you try Marilyn's second suggestion? The mute switch function can be re-assigned from the physical switch next to the volume control to a 'soft switch' in the multi-task bar. Double-tap the Home button to open the multi-task bar, flick the multi-task bar to the right and that will reveal some additional controls - a duplicate volume control and another switch - which can be assigned to be either the orientation lock or the mute button. Since it seems as though you've got the physical switch set as the orientation lock, the soft switch should be the mute control.
    You can change the assignments later on in the 'Settings' menu.
    80534
    Jul 2011
    10
    Audio problem
    Please explain the steps I need to take as if I were a small child as I am very ancient. (1) I double tapped the home switch and flicked the screen as you told me. I am facing the longer side of the iPad with the home switch situated on my right. I see a slide switc on my left for brightness adjustment and a. Slide switch on my right for sound adjustment. I also see on the edges two symbols, one black with a padlock pictured and an orange symbol on my right.Please explain very clearly what I should now do. As separate question please explain the function of the. longer of the two physical switches on the top left of the iPad as it doesn't seem to move stall when I press it( I am looking at the longer side of the iPad with the home switch on my right). Thank you for you patience and advice.
    119 times
    15,248
    Quote Originally Posted by oldfool33 View Post
    OK - you are doing alright and your description was very clear and helpful.
    So - in the multi-task bar - you have identified the brightness control and the 'soft' volume control. The symbol with the padlock in it is the orientation lock and, if it's displaying a padlock, it means that the screen of the iPad won't automatically re-orientate itself if you turn it from landscape to portrait. Using that control (just tap it) you can turn the orientation lock on and off. The orange symbol on the right hand side is the iPod control.
    The fact that you have the padlock symbol in the multi-task bar means that the mute control is assigned to the physical switch. You mention the two physical switches next to each other on the upper right hand side of the iPad (if the Home button is at the bottom). The shorter switch is the Mute control and turns some - but not all - sounds on and off independent of the position of the volume control. Typically it turns off 'systems sounds' such as the arrival of new email.
    The longer switch that you mention is a 'rocker' switch and controls the volume - it doesn't slide but you can press its upper edge to increase the volume and its lower edge to decrease the volume ('upper' and 'lower' being with the Home button at the bottom of the iPad again). If you press and hold the lower edge of the volume control the volume will - after a very short interval - suddenly fall to zero - it's a quick way of turning the sound down. If you want to gradually reduce the volume in small steps you have to repeatedly tap the lower edge of the volume control.
    When you adjust the volume using this control you should see a graphic appear on the screen that shows the level of the volume on a short 'bar scale'.
    OK - try some of these things out and get back to us - we're here to help so don't hesitate to come back with follow up questions. And don't worry about asking 'stupid' questions - there is no such thing. Only the answers might be stupid...
    Have fun and enjoy exploring your iPad.
    80534
    Jul 2011
    10
    Understanding more
    Went to settings,general,use side switch to lock rotation. There is now no tick against mute in settings, and presumably sound is controlled by the sliders in iPod and the slider I mentioned in my last message. But still no sound except when I push th slider and hold it in place for a moment after which it slips back. Any advice as to what next to do. Thanks Tim.
    119 times
    15,248
    OK - but if you've changed the mute control to be in the multi-task bar you'll need to go there now to 'un mute' the iPad. So open the multi-task bar, flick right and change the mute switch so that it's off.
    80534
    Jul 2011
    10
    Further discussion audio
    In the multi-task bar on the extreme left there is now a symbol of a speaker with waves emanating from it. Before my last message I tapped the speaker to eliminate the diagonal line across it. Was that what you meant by un-muting the I pad? or am I missing something important?.
    Still no audio.
    Ewen
  1. Audio Recording
    By James7285 in forum iPad Apps
    Last Post: 12-29-2012, 07:34 AM
  2. iPad headphone audio v dock audio; is there a difference?
    By Pagliacci in forum iPad General Discussions
    Last Post: 04-09-2011, 09:26 AM
  3. Will Skyfire stream audio from flash audio player?
    By wahoowad in forum iPad General Discussions
    Last Post: 04-03-2011, 03:54 PM
  4. Audio Question
    By hoxivuti in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-11-2010, 08:26 AM
  5. iPad Audio
    By DarthMambo in forum iPad Development
    Last Post: 07-10-2010, 01:48 AM
ipad no audio
no audio ipad
no sound adjustment on ipad
no sound from music on ipad
no volume control ipad
no volume on ipad
skyfire no sound
skyfire sound problem
