New iPad 2 and problems with BBC iplayer
This is a discussion on New iPad 2 and problems with BBC iplayer within the iPad Help forums, part of the Apple iPad Discussions category; Hello peeps. Recently bought my lovely new iPad and it's amazing. The only problem is I can't get BBC iplayer to work. Programs don't load ...
Results 1 to 10 of 19
    79250
    Jul 2011
    10
    Hello peeps. Recently bought my lovely new iPad and it's amazing. The only problem is I can't get BBC iplayer to work. Programs don't load in the app (live tv works) and if I try in safari I just get the loading quick time logo. I've tried removing the app no joy, I've rebooted the iPad and no joy and I've done a complete power drain and no joy. I've got 20Mbps virgin media conection and I watch the iplayer no problem on my laptop. Does anyone have any ideas? Thanks in advance.
    116 times
    15,249
    The iPad BBC iPlayer app only supports streaming - no 'downloading' for offline viewing. There are future developments that the BBC are working on that will support both downloading and the use of 3G - you'll probably have seen some well-publicised comments by the BBC on this - but I've not seen a projected date yet for the release of this new version of the app.
    79250
    Jul 2011
    10
    Hi, I'm not trying to watch a program off line just watch any of the catch up programs online. And I can't figure out for the life of my why it won't work. I'm using wifi not the 3G connection. 4od and itvi player work fine it's just the bbci player that won't work.
    116 times
    15,249
    OK - I've just tried this and I get the rotating white bezel for about 5 minutes before the program starts to play. See if you leave it longer it starts to work.
    37823
    477 times
    Cranbrook, Kent, UK
    15,230
    I know I keep saying this in these threads but I don't think it is a problem with the app, I can play all programmes through the iPlayer app with no more than a few seconds delay to start and no buffering, in most cases it appears to be a problem between the router and the iPad. First thing to do is make sure that your routers firmware is up to date, if that doesn't work you may need to change your router but before you do that I would suggest that you try running on the wifi in, say, a Starbucks or maybe a couple of your friends routers, if it works on any of these then it definitely isn't the app and must be the router.
    79250
    Jul 2011
    10
    Thanks for the reply's. I'm going to update the routers firmware later. I don't hold much hope tbh as it's a brand new router but we shall see. I'll let you know how it goes. And I've just been reading on the BBC website this.
    http://www.bbc.co.uk/dna/mbiplayer/N...thread=8083066
    It seems to be a problem lots of people seem to be having.
    37823
    477 times
    Cranbrook, Kent, UK
    15,230
    Quote Originally Posted by Frootshoot
    Interesting link, here is the thing though, if we both have the same app, exactly the same app and mine works fine then I can't see a logical way that the app can be at fault, so we need to look elsewhere. Even if your router is brand new and it's firmware is fully updated it won't necessarily work properly with your iPad. There are lots of threads here on this subject with some good fixes.....it's worth doing a search and some reading before doing anything too drastic.
    46070
    53 times
    Egremont
    979
    It is a very common but not universal problem with iplayer on the iPad. Just because you don't have a fault Gabriel doesn't mean it isn't a problem with the app. I too have seen the fault but it comes and goes sometimes works on my wifi sometimes doesn't. Same if I try other routers or other wifi networks.
    I accept it could be a problem with routers but with so many people reporting it, you would have thought somebody would have figured out a commonality across everybody with the problem. Whether it's certain routers or firewalls or ports needing opened etc.
    79250
    Jul 2011
    10
    Hey. Just finished updating the firmware and no joy. I also logged into next doors wifi (with their permission) and exactly the same problem. They have a different router but on the same isp. So it doesn't make a lot of sense. Tbh though it means I thankfully havnt had to watch eastenders in bed this morning with my missus. So I'm kinda thankful for that.
    37823
    477 times
    Cranbrook, Kent, UK
    15,230
    Quote Originally Posted by DefBref
    I kind of agree with you. The reason that I think it is not the app though, is that in years gone past software conflicts could be found with differing video cards, USB hubs, etc, etc however we all have exactly the same hardware (albeit iPad 1 or 2) and exactly the same software (albeit some may not be updated to the latest iOS and some could be jailbroken) but that aside there is little to explain why it works on mine and many others and doesnt work on other people's iPads. So just looking logically and also from the evidence in other threads it appears to be router conflict (generally) but of course you have a point regarding firewalls, ports, etc........but I think waiting for an app update to cure it will be a long, long wait.
    Either that or everyone can come round to my place and watch mine!
  1. Problems watching BBC iplayer on TV
    By Martc in forum iPad Help
    Last Post: 07-16-2012, 07:07 PM
  2. BBC iPlayer iPad App Out Now, and it Rocks!
    By Maura in forum Apple iPad News
    Last Post: 02-17-2011, 06:40 AM
  3. BBC iPlayer for iPad Coming February 10
    Last Post: 02-08-2011, 08:55 AM
  4. BBC Iplayer for the iPad
    By thomo45 in forum iPad General Discussions
    Last Post: 07-01-2010, 01:48 PM
  5. Get BBC iPlayer on Your iPad
    By iDan in forum Apple iPad News
    Last Post: 04-28-2010, 09:48 PM
bbc iplayer for ipad 2 problems
does ipad support bbc iplayer
does iplayer work on ipad
how can i get more sound on my i pad when watching bbc i player?
i cant get bbc iplayer or itv player to work on my ipad anymore?
ipad 2 iplayer
ipad 2 no iplayer
iplayer not working on ipad
iplayer on ipad 2
why can't i watch bbc america on my cox connect on ipad?
why doesn't iplayer play on an ipad
will the ipad2 support iplayer
Tags for this Thread
