Sync Problem
This is a discussion on Sync Problem within the iPad Help forums, part of the Apple iPad Discussions category; Hello every1
I'm new here...
I have a problem with my ipad
I can't cpy anything in my ipad(photo,movie,music)
When i connect my ipad to ...
05-27-2010 08:49 AM
I have :
Windows 7
Itunes 9.1
The only action that i can do with my ipad in ITUNES is EJECT the ipad !!!
iPad Enthusiast!
have you set up your library so that you can see music files in your Library section?
32 GB WiFi iPad
Have you already sync'd your iPad with another computer? You can only marry one iPad with one desktop. If you try to sync to a second iTunes, it will force your to zapp the contents and refresh. This is a security feature.
Piko
Originally Posted by
robsoule
Dear robsoule i didn't set up my library but i think itunes did it automatically cause i can see my music files in MUSIC field....
pik0
Piko
Dear pik0 thx for your help, but i sync'd my ipad only to my current pc ...
When i connect the ipad to pc , and when i click the IPAD which is in device field i can only see the IPAD word in my itunes , and itunes try to connect to itunes store .....
When ipad sync'd correctly what should be appear in itunes ?
Can i sync ipad manually ?
Banned
sync ipad
well, I suppose you can turn to apple discussion ipad column:
Apple - Support - Discussions - Syncing
- You may not post replies
- You may not edit your posts
Forum Rules
By garyt01 in forum iPad General Discussions
Last Post: 11-27-2011, 01:06 PM
By epb in forum iPad Help
Last Post: 11-05-2011, 08:00 PM
By ptbrown in forum iPad Help
Last Post: 09-27-2010, 01:14 PM
By Sincere11105 in forum iPad General Discussions
Last Post: 04-15-2010, 09:55 PM
By Gayle in forum iPad General Discussions
Last Post: 03-30-2010, 10:14 AM
ipad movie sync issues
ipad movie sync problems
ipad music file problem
ipad sync error 50 windows 7
ipad sync error 54
ipad sync issues windows 7
ipad sync problem
ipad sync problems windows 7
problem syncing movies ipad
problem syncing movies to ipad
problem syncing music
sync problems
