ipad 2 not syncing with ical?
This is a discussion on ipad 2 not syncing with ical? within the iPad Help forums, part of the Apple iPad Discussions category; Hi, Just upgraded to version 4.3.4 - and now the ipad calendar will no longer sync with iCal on my MBP. I've rebooted both, made ...
Results 1 to 3 of 3
    44871
    Hi,
    Just upgraded to version 4.3.4 - and now the ipad calendar will no longer sync with iCal on my MBP. I've rebooted both, made sure that the 'sync all calendars' check box in itunes is ticked, even erased all the calendar data on the ipad and tried to start again from scratch.
    Any ideas?
    Thanks - Henry
    1546 times
    Walla Walla, WA
    15,470
    Sounds like you've tried everything I'd try, except turn off the calendar sync in iTunes, and sync. Then turn it on again and sync.
    Good Luck
    227243
    Jul 2012
    Australia
    Thanks - this just solved same problem I was having with my sync. I didn't need to restart for it to work - just turn off the sync in iTunes, do a sync, then turn it back on and sync again - brilliant.
  1. iCal sync with iPad, iPhone, and MacBook pro.
    By Nicalleto in forum iPad Help
    Last Post: 04-05-2011, 04:18 PM
  2. ical for ipad?
    By ipad1992 in forum iPad General Discussions
    Last Post: 03-26-2011, 12:30 AM
  3. getting iCal on iPad to match weekly view pref
    By macats22 in forum iPad Help
    Last Post: 11-03-2010, 10:49 AM
  4. iPad and Ical sync one way only
    By swampfallgirl in forum New Member Introductions - Site Assistance
    Last Post: 10-28-2010, 02:32 PM
  5. iCal syncing
    By hberninger in forum iPad Help
    Last Post: 07-26-2010, 07:51 AM
ical not syncing with ipad
ical not syncing with ipad calendar
ical will not sync with ipad
ipad and ical not syncing
ipad calendar not syncing with ical
ipad not syncing ical
ipad not syncing with ical
sync ipad calendar with ical
