Question On Charging Ipad
This is a discussion on Question On Charging Ipad within the iPad Help forums, part of the Apple iPad Discussions category; Other than using the USB on a PC or the charging pack can one use the small electrical plugs they sell with a USB port ...
Results 1 to 3 of 3
    4993
    3 times
    May 2010
    St.Louis Mo
    415
    Other than using the USB on a PC or the charging pack can one use the small electrical plugs they sell with a USB port on them,the output on the plug is DC 5.0V + or- 5%.
    Thanks for any information on these plugs.
    Al.
  2. #2
    4250
    3 times
    May 2010
    Kalifornistan
    145
    Quote Originally Posted by Al Rogers View Post
    Al.
    What is the wattage or ampere rating? The Ipad needs 10W (Watts)/2A (Amps). The voltage you mentioned will work but if the wattage is lower than 10W or if the ampere rating is lower than 2A, it will take longer to charge the iPad.
  3. #3
    4993
    3 times
    May 2010
    St.Louis Mo
    415
    Thanks for the info.
    Al.
Sponsors
  1. Charging the iPad
    By pdhughes1 in forum iPad Help
    Last Post: 09-20-2011, 03:58 PM
  2. Charging my ipad with my pc
    By clarman in forum iPad General Discussions
    Last Post: 05-27-2010, 04:42 PM
  3. Charging from computer?
    By mamiamjo in forum iPad Help
    Last Post: 04-19-2010, 04:45 PM
  4. New iPad not charging via USB? Check here
    By JohnnyApple in forum Apple iPad News
    Last Post: 04-05-2010, 02:54 AM
  5. Charging module
    By ptmark in forum iPad General Discussions
    Last Post: 04-04-2010, 03:04 PM
how many volts does an ipad need to charge
how many volts does it take to charge an ipad
how many volts in ipad charger
how many volts is the ipad charger
how many volts to charge an ipad
how many volts to charge ipad
how many watts does a ipad use
how many watts does an ipad use
how many watts does ipad use
how many watts in an ipad
how many watts ipad
how many watts is an ipad
how many watts is an ipad charger
how many watts is the ipad charger
how many watts to charge an ipad
how many watts to charge ipad
ipad charging voltage
ipad wattage
wattage for ipad
wattage of ipad
