Itunes - no sound
This is a discussion on Itunes - no sound within the iPad Help forums, part of the Apple iPad Discussions category; Hi I am new to Itunes and IPAD and wonder if someone can help me with an Itunes question. I tried to put one of ...
Results 1 to 7 of 7
    75428
    Jul 2011
    11
    Question Itunes - no sound
    Hi
    I tried to put one of my CDs into my library fo the first time. The song titles appeared etc., but there was no sound on any of the songs. Any ideas what went wrong?
    Thanks for your help.
    Kazza
    119 times
    15,248
    How did you convert them/rip them and how did you then transfer them to the iPad?
    75428
    Jul 2011
    11
    Question iTunes - no sound
    Hi
    I saved a CD in ITunes and after I synced Itunes with my IPad there was no sound when playing the CD. I therefore took the CD off my IPad and put it on ITunes again. This time I pressed the play button in ITunes and again no sound. The CD plays fine on a CD player. Any ideas why this happened.
    Kazza
    1518 times
    Walla Walla, WA
    15,429
    Ok, that is weird. Is it only that CD, or do other CDs fail to play in iTunes as well?
    Also, or you playing the CD directly, or are you importing it and playing it? If you are importing first, check your CD import settings under iTunes Preferences (see attachment). Unless you have reason to pick other settings, the ones listed should work very well for songs you intend to sync with the iPad.
    75428
    Jul 2011
    11
    Hi
    At the moment it is just that CD. It was the first time I used ITunes. Is there a way of just syncing one CD only to your IPad or do I have to sync the whole Lot again - photos, videos and apps (it took forever to copy over last time).
    Thanks.
    kazza
    1518 times
    Walla Walla, WA
    15,429
    If you look at the sync settings for music you'll see all kinds of options for syncing. Change what does and does not sync there. It should not affect any other sync options.
    If you are currently syncing all your music, then adding or deleting music from the iTunes library will only change what you changed. If you are syncing selected albums, artists, whatever, only the changes you make in the settings will be synced.
    75428
    Jul 2011
    11
    Unhappy
    Hi
    I have deleted the CD from Itunes with no sound. Tonite I tried to import two different CDs to Itunes and again, when I clicked on each of the songs, no sound (Itunes did however show how many minutes each of the songs were once imported). I again deleted the CDs from Itunes as no point in syncing to IPAD. I put each of the CDs in the CD drive and each one played. I also tested other CDs that are already in Itunes and they play fine.
    Any more ideas where I am going wrong?
    Kazza
  1. Can someone help me with app - no sound
    By Ipadee in forum iPad Apps
    Last Post: 08-28-2011, 07:31 PM
  2. Sound gone
    By Sjwred in forum iPad Help
    Last Post: 04-28-2011, 04:04 AM
  3. Bluetooth and Bose sound dock suddenly drops sound level
    By J_mccasland in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 03-06-2011, 11:16 AM
  4. Replies: 0
    Last Post: 03-01-2011, 12:19 AM
  5. How Do These Sound Boxes Make Sound?
    By padmeup in forum iPad General Discussions
    Last Post: 09-10-2010, 09:08 PM
ipad itunesu no sound
no sound from cds in itunes
no sound from my itunes albums on ipad
no sound in itunes on ipad
no sound itunes ipad
no sound on itunes
no sound on itunes on ipad
no sound on itunes what do i do
