IPad 2 won't connect to wifi extender
This is a discussion on IPad 2 won't connect to wifi extender within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I purchased about 2 months ago my first Ipad 2 (WiFi 32gb). My IPad had terrible connection in my bedroom but I had good ...
Results 1 to 5 of 5
    77975
    Jul 2011
    Broken Arrow
    Hi,
    I purchased about 2 months ago my first Ipad 2 (WiFi 32gb). My IPad had terrible connection in my bedroom but I had good connection with two Iphone 4s and my Samsung Laptop R series laptop. I switched my routher from mixed g&n to g and it didn't help. So I went to the apple store and they gave me another Ipad. This didn't solve the problem so I started doing research to extend my WiFi range.
    So I purchased a Netgear WN300RP WiFi Range Extender and had full range for all of my devices in my bedroom. After a day, I lost my connection to my ipad 2. I reset the extender with my router D Link Dir655 and it worked again for less than a day. It shows connected but the safari browser says "Safari cannot open the page because it is not connected to the internet". So I can't keep trying to communicate my router to the extender just to get internet connection for a day or so. I'm thinking its the Ipad and not the extender so I'm hoping someone will help out with advise.
    Carlos
    Router D Link DIR655 (mixed g & n)
    Netgear Universal WiFi Range Extender WN300RP
    Ipad 2 WiFi 32 GB OS 4.3.3
    21158
    Nov 2010
    Texas USA
    23
    No guarantees but . . .
    Go to your Settings, WiFi and remove/forget the connection you are trying to use. Then, reset the iPad: Hold the Sleep and Home buttons until the Apple logo appears.
    Go back to Settings, WiFi, after the reset is complete and connect to the desired network.
    This has worked for me in a similar situation. Good luck.
    bw
    77975
    Jul 2011
    Broken Arrow
    Thanks for the quick response. I did call apple and they recommended the same. I was aware of turning off the device, I didn't know there was a reset feature. So far today I have not lost connection, I will keep an eye on it tomorrow and see if I have any problems. Thanks for the help!
    Carlos
    151399
    Jan 2012
    CT
    Don't understand how to "remove/forget the connection". I can't find any way to do that.
    48854
    77 times
    Weston WI
    856
    Quote Originally Posted by tylersmith
    In settings go to wi-fi then the connected wi-fi, click the > and choose forget this network. I've found that sometimes you can reconnect without restarting, but you may need to restart or reset (reboot)
  1. ipad 2 will not connect to wifi
    By gcclubs in forum iPad 2 Forum
    Last Post: 01-07-2013, 04:26 PM
  2. Connect ipad with pc - wireless or wifi
    By georgevj in forum iPad Help
    Last Post: 12-24-2011, 11:11 PM
  3. Ipad 2 won't connect wifi after activate the 3G
    By caparuni in forum iPad Help
    Last Post: 06-13-2011, 01:16 AM
  4. ipad won't connect to home wifi now
    By yorky48 in forum iPad Help
    Last Post: 04-11-2011, 09:13 AM
  5. How do you connect Wifi speakers to ipad
    By macfoot in forum iPad Help
    Last Post: 12-23-2010, 11:10 AM
cannot connect ipad to netgear extender
connect an iphone to a wifi range extender
connect ipad to wifi extender
force ipad to connect to extender
ipad cannot connect to netgear range extender
ipad cannot connect to wifi extender
ipad won't connect to range extender
ipad won't connect to wifi extender
ipad wont connect to netgear extender
ipad wont connect to netgear wn300rp
reset router tp link ipad safari not working google
tp link range extender ipad
