Problem with 3G
This is a discussion on Problem with 3G within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I just joint this forum and I am having problem in my iPad 2. I have a 3G access but every now and then ...
Results 1 to 4 of 4
Thread: Problem with 3G
    78083
    Jul 2011
    Problem with 3G
    Hi, I just joint this forum and I am having problem in my iPad 2. I have a 3G access but every now and then I need to switch off and on the flight mode to get connected to 3G. My vendor told me to reset network but it still doesn't work. I even get the SIM card replaced but still the problem still there. Can anyone help?
    119 times
    15,248
    Quote Originally Posted by tanky View Post
    I've moved this to a new thread; it's not a good idea to 'hijack' another thread as it leads to confusion. But, no problem.
    78083
    Jul 2011
    Noted with thanks, Tim
    119 times
    15,248
  1. Problem with IPF app
    By idave23 in forum Official iPadForums.net App Forum
    Last Post: 07-07-2011, 11:22 PM
  2. App problem
    By Frantob in forum iPad Help
    Last Post: 06-28-2011, 09:29 PM
  3. HBO GO problem
    By Rafafito in forum iPad Help
    Last Post: 06-11-2011, 10:34 PM
  4. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  5. problem with 3G!!!
    By bahram in forum iPad Help
    Last Post: 11-01-2010, 06:54 AM
hbo go problems with 3g
