Charging the iPad
This is a discussion on Charging the iPad within the iPad Help forums, part of the Apple iPad Discussions category; I was told or read that charging the iPad is quicker if the iPad is turned off and charged through an outlet instead of through ...
Results 1 to 7 of 7
    463
    Feb 2010
    Chesapeake, VA
    Question Charging the iPad
    I was told or read that charging the iPad is quicker if the iPad is turned off and charged through an outlet instead of through a computer USB port. My issue is whenever I plug in my iPad, I power it down first, then plug it in, but as soon as it is plugged in, it turns itself on and goes to sleep mode. Is there a power setting somewhere that I am missing or is this the normal mode of operation?
    PDH
  2. #2
    iPad Ninja
    3495
    4 times
    May 2010
    Switzerland
    2,024
    Charging the iPad
    I guess whoever told you 'off' meant Sleeping. But otherwise yes, the statements are true.
  3. #3
    4636
    May 2010
    Lithuania
    Charging the iPad
    Try first to plug-in and then power down.
    Sent from my iPhone using Tapatalk
  4. #4
    1596
    30 times
    Mar 2010
    3,207
    Charging the iPad
    I would suggest charge using ac adapter supplied. It is faster. Col
    Cheers
    Col
    col.bris, Brisbane Australia
    iPad User Guide
    Forum Rules. Please Read.
    Hacking Section Rules
  5. #5
    iPad Master!
    2051
    Apr 2010
    home
    1,353
    Quote Originally Posted by col.bris View Post
    +1 to this... plus AC charging is more reliable as well... the iPad requires 10 watts to charge correctly, so many USB ports cannot give it the power it needs. It will still charge on a less than 10 watt USB (even if it says it is not charging) but it will take a loooooooong time....
    Any device will charge faster if it is off, but the iPad does in fact still charge if on if it is getting the charging power it needs.
    When it comes on as you plug it in, it is just telling you it is plugged correctly. It will shut off on it's own in a few seconds......
    Bremen Cole
    iPad 1st Gen 16G
  6. #6
    100658
    Sep 2011
    Poole, U~K
    7
    IPad not charging
    My iPad sometimes charges fast, sometimes slow (only a 10% increase in charge level over night), and sometimes not at all. In fact sometimes it seems as if plugging it in is actually draining the power from it.
    I am plugging it into the mains, not a PC, and I am using a proper apple charger. It always says it’s charging.
    I have tried restarting it (sometimes that works but not always) and have exited all the apps that were running.
    Yesterday it was charging fine while playing music, but it then crashed out during playing a track, restarted itself, and then had the charging problem.
    I suspect it’s software rather than hardware since the problem is intermittent.
    It’s an iPad 1, now a year old.
    Any thoughts? I can’t be the only one with this problem, surely?
  7. #7
    89227
    5 times
    Aug 2011
    UK
    229
    Quote Originally Posted by mrbrift
    IPad not charging
    The iPad as said needs a stronger charger than the iPhones, you can get a free program called asus (something - just search this forum for asus). that increases the default power available from PC USB ports.
    I suggest this as a way of eliminating a faulty charger
Sponsors
  1. Battery charging
    By Seadog in forum iPad Accessories
    Last Post: 07-05-2010, 10:29 PM
  2. Charging my ipad with my pc
    By clarman in forum iPad General Discussions
    Last Post: 05-27-2010, 05:42 PM
  3. Charging from computer?
    By mamiamjo in forum iPad Help
    Last Post: 04-19-2010, 05:45 PM
  4. New iPad not charging via USB? Check here
    By JohnnyApple in forum Apple iPad News
    Last Post: 04-05-2010, 03:54 AM
  5. Charging module
    By ptmark in forum iPad General Discussions
    Last Post: 04-04-2010, 04:04 PM
charge ipad
charge ipad first time
charging an ipad for the first time
charging ipad first time
charging ipad for the first time
charging the ipad for the first time
charging your ipad for the first time
first charging ipad
first time charging ipad
first time to charge ipad
how long to charge ipad first time
how to charge ipad first time
initial ipad charge
ipad 1 charging time
ipad charging time
ipad first charge
ipad first charge time
ipad initial charge
ipad initial charge time
ipad turns on when plugged in
Tags for this Thread
