Docs To Go syncing issue
This is a discussion on Docs To Go syncing issue within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I use Docs To Go at home with my wireless service and have absolutely no issues syncing my iPad 2 to my Macbook Pro. ...
Results 1 to 2 of 2
    75998
    Jul 2011
    Hi,
    I use Docs To Go at home with my wireless service and have absolutely no issues syncing my iPad 2 to my Macbook Pro. However, whenever I travel and use the wireless service either at a hotel or an airport, I get an error message on Docs To Go that tells me that I must have both units connected to the same network. I am positive that both units are. Any suggestions on what I'm not seeing here?
    Mark
    579 times
    Dayton, WA
    13,188
    Many hotspot/hotel networks block device to device protocols. This is for security. It helps prevents one guest from seeing and fiddling with files on another guest's device, even if they've accidentally left them shared.
    To work around this you might try DropBox. Since it is on the internet both devices will be able to see and access the storage space. Docs To Go also provides built in access to DropBox, so I am told.
  1. Syncing Docs
    By Drummo in forum iPad General Discussions
    Last Post: 04-30-2011, 05:50 AM
  2. docs to go spreadsheet issue
    By dough54321 in forum iPad Help
    Last Post: 01-28-2011, 11:31 PM
  3. Syncing iPad without syncing music
    By Mike_73 in forum iPad Help
    Last Post: 01-10-2011, 03:49 AM
  4. Mobile Me Syncing Issue
    By clarkee in forum iPad General Discussions
    Last Post: 05-09-2010, 02:29 PM
  5. iWorks and Google Docs Issue
    By AZRaptor in forum iWork Forum
    Last Post: 04-16-2010, 01:17 PM
can you sync documents to go wirelessly
docs to go ipad sync problems
docs to go not syncing
docs to go sync problems
docstogo not syncing dropbox
docstogo sync problems
documents to go not syncing with dropbox
documents to go sync problem
documents to go sync problems
ipad tells me that i am guest
sychronization issues docs to go
syncing problems with documents 2 go for ipad2
