The camera works and it rings but no connection is made. It wasn't doing this until very recently.
This is a discussion on Face time not connecting within the iPad Help forums, part of the Apple iPad Discussions category; The camera works and it rings but no connection is made. It wasn't doing this until very recently....
I've moved your post to the Help section too.
Thanx a lot . That was a big help. The " jiggly icon" remedy worked. I'll be switching my iPad off weekly from now on too.
TTT
