Results 1 to 10 of 10
    48037
    10
    Should iPad batteries ever be discharged?
    An Applecare supervisor told me that:
    (1) I should not let my iPad 2 run out of power while the system running, because that crashes the software and apparently creates some risk.
    (2) I should never run the battery down to zero voltage. He said that iPad 2 batteries should never be completely discharged, and recommended NOT going below 20%.
    However, see this web page:
    Apple - Batteries - iPad
    Where, I quote, it says:
    "For proper reporting of the battery’s state of charge, be sure to go through at least one charge cycle per month (charging the battery to 100% and then completely running it down)."
    The advice I just quoted seems to encourage running the iPad charge down while the software is live, and definitely seems to suggest running the battery down to 0%.
    Who is right? The battery page, or my applecare supervisor?
    116 times
    15,249
    Absolutely follow the Apple advice. For more technical information look here...
    Charging Lithium-ion – Battery University
    30432
    Wales
    113
    Good article Tim, thanks for that.
    Sent from Wales, using my iPad & iPF.
    15433
    17 times
    Sep 2010
    773
    Quote Originally Posted by Tobyr21 View Post
    Terrible advice from the supervisor.
    (1) The system will auto shutdown when the battery gets to a certain threshold - the battery is not completely empty at this point but the system will close down running apps (saving their state) and then power off to save the integrity of the system.
    (2) As per above, the battery is not actually hitting zero voltage, it is calibrated to power down before then - even though the battery meter may say 1% remaining, there is actually more power available - this 1% is just how much running power is available before it shuts down. As per Apple's docs, you need to use the range from 100% down to 1% occasionally for the battery meter to be able to calibrate properly based on your usage. This isn't an exact science, it's an estimate based on what you are doing and what you have done previously.
    48037
    10
    My supervisor called me and corrected his advice
    He told me essentially what this thread advises.
    Thanks.
    14699
    12 times
    Sep 2010
    Woodlands MB, Canada
    349
    Here's what Apple has to say about the batteries they use in the iPad: ---> http://www.apple.com/batteries/ipad.html
    15433
    17 times
    Sep 2010
    773
    Quote Originally Posted by jwt873
    That link was already in the original post.
    48037
    10
    The Apple battery page suggests that it's not a good idea to keep the battery charging at 100%. That might mean that we should be careful not to overcharge our batteries. But it could just as easily mean that when the iPad SAYS it is at 100%, the battery is not really 100% and the iPad is being careful not to fully charge the battery.
    To put it another way, when the iPad says the battery is 100%, does that really mean the iPad has allowed the battery to reach its physical maximum charge?
    Does anybody know?
    iPad Ninja
    62473
    63 times
    Jun 2011
    1,608
    There is no issue in keeping the battery charged. Why Apple wants you to let it run down once in a while is so they can calibrate the percent charged indicator.
    As the battery slowly loses its ability to retain a new-battery full charge, the need to adjust this increases. If you let the battery go flat once in a while, the next full charge will reset the 100% indicator.
    That's all the document addresses, not actually the health of the battery.
    -t
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    T That might mean that we should be careful not to overcharge our batteries.
    You can not over charge your battery.
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
  1. A Question About Batteries
    By Knightoftheapp in forum New Member Introductions - Site Assistance
    Last Post: 04-12-2011, 06:13 PM
  2. External iPad Batteries: total run time ranging from 34 to 99 hours
    By 4phun in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 11-01-2010, 10:05 PM
  3. Original iPad Batteries x2--- 40 bucks!
    By Ultrimate in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-27-2010, 02:52 PM
  4. Batteries
    By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-11-2010, 07:38 PM
  5. Who will be first to two full batteries?
    By JohnnyApple in forum Off-Topic
    Last Post: 03-22-2010, 11:52 PM
apple care - should you let ipad battery go flat
ipad 1% discharge
ipad2 needs full discharge
is it good to let the battery ipad battery flat
is it ok to let the ipad run out
let my ipad 2 go to zero battery
letting battery run down
should i let ipad battery completely run down
should i let ipad battery go completely flat
should i let ipad battery run down before charging
should i let my ipad battery run out
should you let ipad battery run down
Tags for this Thread
