How i can unlock my ipad tilting lock?!
This is a discussion on How i can unlock my ipad tilting lock?! within the iPad Help forums, part of the Apple iPad Discussions category; I have a problem in my iPad , and I wanna someone to help me to solve it , I have a lock on the ...
Results 1 to 10 of 15
    73604
    Jul 2011
    11
    I have a problem in my iPad , and I wanna someone to help me to solve it , I have a lock on the upper right hand on my iPad next to the battery charge icon, this lock preventing me from tilting my iPad , how I can unlock it please?
    116 times
    15,249
    There are two possibilities. On the iPad2 the 'orientation lock' is either controlled by ---
    (1) the switch next to the volume control or....
    (2) -- press the Home switch twice quickly and you'll open up the multi-task bar. Now 'flick' the screen to the right and you'll see - in the multi-task bar - the 'orientation control'
    It will be one or the other (it's configurable in the 'Settings' menu)
    So, which ever it is, either the switch or the 'soft' control in the multi-task bar, you'll be able to restore the orientation control of the iPad.
    Let us know if this doesn't work - or even if it does....
    73604
    Jul 2011
    11
    Actually it doesn't work
    Ughhhhhhhhhhh
    116 times
    15,249
    Quote Originally Posted by shaymaa View Post
    Ughhhhhhhhhhh
    So - you've tried both suggestions? OK - reboot....
    Press and hold the Power and Home buttons together for a long time - perhaps 20 seconds..
    The iPad will reboot - let us know if this fixes the problem...
    Rog
    Rog is offline
    59399
    May 2011
    USA
    114
    Look at my attachments and make sure you looked in the correct places.
    Attached Thumbnails Attached Thumbnails How i can unlock my ipad tilting lock?!-image-1767248073.png   How i can unlock my ipad tilting lock?!-image-211848646.png
    73604
    Jul 2011
    11
    I reboot ,and it didn't work too, and I looked at ur attachment and I don't have this option on my setting inside the general option ?
    116 times
    15,249
    Some applications can enforce an orientation lock. So double-click the Home button to open the multi-task bar, then press and hold any icon in the multi-task bar until the icons start to jiggle. Now close all the apps, one-by-one, by touching the '-' sign on the top left hand corner of each app. Once all the apps are closed, close the multi-task bar by pressing the Home button and see if the problem is cured.
    73604
    Jul 2011
    11
    I doubled click the Home button to open the multi-task bar, then I press and hold all the icons in the multi-task bar until they start to jiggle. And i close all the apps, one-by-one, by touching the '-' sign on the top left hand corner of each app. And after all the apps are closed, i closed the multi-task bar by pressing the Home button and nothing change Tim , the problem is still the same .
    Rog
    Rog is offline
    59399
    May 2011
    USA
    114
    When you use the slide switch by the volume rocker switch does it mute and unmute or lock and unlock the rotation?
    It will only do one or the other.
    Are you able to double-tap the home button and swipe right to see the lock rotation icon and iPod controls?
    73604
    Jul 2011
    11
    And Rog I don't have that features that u attached to me , I have the old iPad the 4.2.1
  1. unlock
    By thedriver2011 in forum iPad Hacking
    Last Post: 04-02-2011, 11:27 AM
  2. Replies: 13
    Last Post: 03-29-2011, 06:53 PM
  3. tap to unlock
    By tidus10 in forum iPad Hacking
    Last Post: 02-13-2011, 05:03 PM
  4. JB/Unlock iPad 64 gb / 3g on 3.2.2
    By Rugbier in forum iPad Hacking
    Last Post: 01-05-2011, 10:27 AM
  5. Do I need to Unlock?
    By gusz in forum iPad Hacking
    Last Post: 06-25-2010, 04:18 PM
how do i unlock ipad tilt lock
how to lock ipad tilt
how to unlock the tilt on ipad
how to unlock tilt on ipad
ipad tilt controls dont work
ipad tilt doesn't work
ipad tilt lock
ipad tilt not working
ipad what is lock upper right hand. ext to battery
there's a lock logo in the upper right hand screen on my ipad ?
tilting problems on ipad
unlock tilt function ipad
