help with cucusoft converter
This is a discussion on help with cucusoft converter within the iPad Help forums, part of the Apple iPad Discussions category; I am trying to convert movies such as Avatar and Transformers 2 to high quality movies on my iPad. The movies once converted are around ...
Closed Thread
Results 1 to 2 of 2
    4908
    May 2010
    california
    I am trying to convert movies such as Avatar and Transformers 2 to high quality movies on my iPad. The movies once converted are around 2.2 GB but the output file is bad. When the software is used to create large files it doesn't load into iTunes. I checked the properties of the file and it appears the problem may be related to the fact that the file properties shows no Length, Frame width, Frame Height, Data Rate, Total bitrate, or Frame rate info and also will not open using Quicktime.? Quick time says "Error 2048: Couldn't open the file AVATAR.mp4 because it is not a file that Quicktime understands?" Handbrake will not recognize the file either. I have changed the Profile settings for the "Split Output File Size" from 1024000 to 2400000 to keep the software from splitting the output into separate files, cucusoft hasn't been any help at all! No phone number and same lame response to inquiries "try changing split output size if that doesn't work change to a smaller file size" e.g. less resolution. It appears that cucusoft took their iPhone converter and added iPad to it and released it If I wanted low res (iPhone resolution videos on my iPad I would have stuck with the previous version of cucusoft!!!) any help?
    Moderator
    131244
    601 times
    Dec 2011
    Regina,Canada
    14,319
    Quote Originally Posted by F1Fanatic View Post
    Was this ever resolved? I just downloaded the software and in the trial it worked no problem, but in the purchased version the files are being split...
    It is unlikely that the OP will come back after almost 3 years to answer this question. I've moved your post to its own thread, where it will receive better attention. With that, we'll close this thread
  1. DVD to iPad Converter - what do you use?
    By GetAloha in forum iPad Help
    Last Post: 08-28-2012, 10:13 AM
  2. iPad Converter - Handbrake
    By faisj in forum iPad General Discussions
    Last Post: 05-28-2010, 09:18 AM
  3. Converter
    By Iphy in forum Off-Topic
    Last Post: 04-30-2010, 12:24 PM
best cucusoft settings
best settings for cucusoft ipad
cucusoft converter problems
cucusoft forum
cucusoft help
cucusoft ipad settings
cucusoft phone number
cucusoft settings ipad
cucusoft splits movie
cucusoft, setting output size
help with cucusoft
why does cucusoft split files
Tags for this Thread
