Youtube works fine on 3g connection but not on Wifi
This is a discussion on Youtube works fine on 3g connection but not on Wifi within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I got a iPad2 last week. When I run YouTube application on my iPad using 3G connection, the video works fine. When I run ...
Results 1 to 3 of 3
    73359
    Jul 2011
    Hi,
    I got a iPad2 last week. When I run YouTube application on my iPad using 3G connection, the video works fine. When I run the same application using wifi connection, I got the message: this move could not be played. All other internet applications work well on iPad using wifi.
    This problem occurs on my iPhone 3GS too.
    When I access the same video on YouTube with my PC on the same wifi, it works fine.
    Anybody else has facing this problem?
    Regards.
    Rog
    Rog is offline
    59399
    May 2011
    USA
    108
    Many people have posted similar issues.
    In my experience it turns out to be a router setting. IOS devices seem to have issues with the "N" speed setting on some routers.
    You should download the free speedtest app and test the speed on your iPad. You should get at least 1 mbit download. I get up to 20 mbit at times.
    I recommend most people to turn off the N speed setting on the router and set it to G or B/G and retest with speedtest.
    If that doesn't seem to make a difference I'd try changing the wifi channel from auto to a single channel and retest.
    Let me know how this works for you.
    By the way Welcome to the Forums!
    73359
    Jul 2011
    Thanks Rog!
    I am running the iPad on other WAN and the YouTube is working well.
    You are right! Next week I will change my wifi configuration as you suggested.
    Regards.
    Tulio
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. Slow YouTube Connection
    By Snowmaven in forum iPad Help
    Last Post: 03-04-2011, 11:45 AM
  3. Replies: 3
    Last Post: 12-29-2010, 11:45 AM
  4. Replies: 3
  5. Replies: 8
    Last Post: 07-11-2010, 09:39 PM
iphone wont play video on wifi
why wont youtube work on my wifi
why wont youtube work on wifi
youtube doesn't work on wifi
youtube doesn't work with wifi
youtube wont play on wifi
youtube wont work on my wifi
youtube wont work on wifi
