Gmail. Causing problems can anyone help
This is a discussion on Gmail. Causing problems can anyone help within the iPad Help forums, part of the Apple iPad Discussions category; I have a ipad2. And iMac. The iMac is using mail via virgin media , when I added mail to the iPad using the same ...
Results 1 to 4 of 4
    72948
    Jul 2011
    I have a ipad2. And iMac. The iMac is using mail via virgin media , when I added mail to the iPad using the same addresses , I ended up not only my virgin accounts but also gmail with same account , gmail as embedded itself Also on the iMac , it keeps downloading old emails that will not delete via mail . It also creates email for every word that I type .even though It only sends one .
    How can you get rid of it. As i never wanted it. But must have hit the wrong key
    Peter
    iPad Junkie!
    66771
    Jun 2011
    Arizona
    175
    If I understand correctly…
    On the Mac select Mail/Accounts and see the mail account on the left column and highlight the one you want deleted. Go to the bottom and click the minus (-) button and you’re done. Then start over with the correct account you want to configure.
    Ok, on the iPad select Settings/Mail…/Accounts/ click the arrow. A screen appears which allows to select ‘Delete’. Go back to Accounts and select ‘Add Accounts’ and start over. In your case, you will select ‘Other’ from the options list to configure Virgin, etc..
    Dan
    72948
    Jul 2011
    Quote Originally Posted by SaberOne
    Hi thanks for replying
    However. I have been trying to do that , but I tried again when you replied on the iPad I removed all accounts and added one and gmail still came up , I tried each one in turn , removing each one before trying the next , but they all brought gmail as well
    Regards Peter
    579 times
    Dayton, WA
    13,187
    This is most likely being cause by your Virgin Mail setup on the server.
    You've probably associated a GMail account with it. Go to your Virgin Mail account in a browser and go through all the settings to find and disassociate the GMail account.
  1. Gmail problems
    By iceman72 in forum iPad Help
    Last Post: 05-17-2011, 06:46 PM
  2. Gmail contact sync problems
    By Hskoog in forum iPad Help
    Last Post: 03-20-2011, 06:08 PM
  3. Official Apple cover with keyboard dock causing problems...
    By SexyBack in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 12-27-2010, 11:30 AM
  4. Gmail problems on iPad. Help Please!
    By jerliz in forum iPad General Discussions
    Last Post: 11-05-2010, 09:38 PM
  5. Handbrake causing jagged lines?
    By katieB in forum iPad Help
    Last Post: 07-11-2010, 01:27 AM
disassociate gmail account from ipad
gmail for ipad 3 get rid of left column
gmail has troubles opening with ipad
gmail help for ipad
gmail help ipad
gmail ipad login error
gmail issues with imac
gmail keeps downloading messages
gmail login issues ipad
gmail login problems on ipad
having trouble opening gmail on ipad
problems opening gmail with ipad2
