How long it takes to charge the iPad2?
This is a discussion on How long it takes to charge the iPad2? within the iPad Help forums, part of the Apple iPad Discussions category; I'm talking about the charging with a wall charger (220/230V). In 5hours my iPad2 charged only to 60% and the charger is really hot. Is ...
Results 1 to 5 of 5
    46636
    213
    Is that normal?
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    Try charging the iPad from your computers USB port, ignore the not charging icon, it is charging just slower. If your iPad charges up to 100% from the USB port, the problem lies with the mains charger, it shouldn't get more than just warm, not hot. Ask Apple for a new charger.
    Good Luck
    Pocobear
    46636
    213
    Quote Originally Posted by Pocobear View Post
    I have Asus AI Charger installed so it shows me that it's charging when it's connected to my PC.
    But still charges very slow. Just few percents in two hours.
    I need something to compare with. What is a normal charge time from the mains and USB? Thanks!!!
    18578
    10 times
    Oct 2010
    Virginia, usa
    608
    Mains should be about 2-3 hours, USB 4-5 hours roughly. Try charging it on your PC without AI Charger. If your motherboard doesn't support AI Charger (all Asus motherboards are not supported), it might be slowing the charging down, instead of speeding it up. Do you know someone with an iDevice that would let you try to charge it up with your iPad charger and your PC, to see if they have any problems charging. If they don't then, worst case it's probably a bad battery.
    And, one more thing, have you tried letting the iPad discharge completely until it shuts off, and then charge it up fully, this is supposed to calibrate the battery indicator. I could simply be that it's really charged fully up, but the indicator is wrong, never showing a full charge on it. The mains charger getting hot worries me. Points to bad charger or bad battery.
    Good Luck
    Pocobear
    46636
    213
    Hi
    I suspected that my non genuine Apple cable is somehow related to the issue. I'm now charging from mains with original cable and.. And now in a bit more than one hour my battery is already 40% full. So i expect that it will take another max 2 hours till full charge.
    How come non genuine usb cable is limiting the charge speed? In both cases I used the original 10 w charger.
  1. New iPad2 won't charge
    By lstrom2 in forum iPad Help
    Last Post: 06-21-2011, 12:23 AM
  2. How long does a charge last?
    By PNova in forum iPad General Discussions
    Last Post: 06-10-2011, 12:39 PM
  3. Why does it take 5so long for it to charge?
    By Tapmyapple in forum iPad 2 Forum
    Last Post: 04-13-2011, 08:54 AM
  4. My iPad2 won't charge to 100%
    By FrankP99 in forum iPad 2 Forum
    Last Post: 03-19-2011, 06:26 AM
  5. Batteries-how long to charge
    By CMFox in forum iPad Help
    Last Post: 06-13-2010, 01:07 PM
how long does it take to charge a mini ipad2
how long does it take to charge an ipad
how long does it take to charge ipad2
how long it takes to recharge an ipad
how long it takes to recharge ipad
how long to charge an ipad2
i pad battery taking too lon to charge
ipad 2 takes too long to charge
ipad 2 taking too long to charge
why does it take so long for my i pad to charge
why does my ipad take so long to fully charge
why is my ipad taking so long to charge
