Help With Camera Connection Kit
This is a discussion on Help With Camera Connection Kit within the iPad Help forums, part of the Apple iPad Discussions category; I purchased the Ipad Camera Connection Kit. I put an SD card into the card reader and plug it into the Ipad and I get ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 24
    4101
    May 2010
    Brooklyn, NY
    12
    I purchased the Ipad Camera Connection Kit. I put an SD card into the card reader and plug it into the Ipad and I get a message that the USB device is not supported. I have several videos on it. It is a PNY 8GB SDHC card. I also just tried a SanDisk 4GB card as well. No good.
    This is the Ipad SD Card reader. Shouldn't it work?
    Any thoughts?
    Dave...
  2. #2
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    are the memory cards formated in Fat32?
    also as far as i know it only works with photos, not videos.
    the camera connector kit just lets you import photo's from cameras or sd cards onto the ipads internal memory. you cant view/edit anything directly on the SD card.
  3. #3
    Supporting Vendor
    456
    Feb 2010
    Asia
    1,275
    Smile
    Quote Originally Posted by Dave View Post
    Any thoughts?
    Dave...
    The problem come from the type of card you use, i got the same trouble with one SD card , i try an other one from a small Canon we have and work like charm so now i know from where that come … by the way if you have an 3GS iPhone you can also connect it to the iPad as camera using the USB port and Apple cable
    Nobody is perfect and me the first
    Ipad essential accessories
  4. #4
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    Quote Originally Posted by IpadOne View Post
    Just to download pictures you already took with the iphone, not as an actual camera.
  5. #5
    4101
    May 2010
    Brooklyn, NY
    12
    Thanks for the input!!!
    Actually the SD card adapter can be used to transfer videos as well per Apple's documentation.
    The documentation also indicates that SDHC cards can be used, as well as MicroSD cards, provided that you have the adapter for it.
    I tried two SDHC cards and they gave me the same error message. I also tried a MicroSD card, in an SD adapter, and then inserted that into the Apple SD card adapter and that did work.
    Strange.
    I am going to try the format issue as suggested by Mike.
    I will keep you guys posted. Any other thoughts would also be appreciated!!!
    Dave...
  6. #6
    4101
    May 2010
    Brooklyn, NY
    12
    I reformatted the SD card using FAT 32. It still does not work.
    This is particularly irritating as I purchased an 8 GB SDHC card today specifically to store videos on to carry with me to transfer to my Ipad when I so desire. And again, the documentation that comes with the Camera Connection Kit specifically says it works with SDHC.
    I guess I will call Apple on Monday.
    D...
  7. #7
    Supporting Vendor
    456
    Feb 2010
    Asia
    1,275
    Smile
    D...
    Believe me Apple can’t help you as the reader work … i am on Mac so i can’t help you if you are in PC , but i am pretty sure the problem come from the card format, of course if your card work in other device i mean not broken or corrupted …
    one of my card don’t work in my iPad so i reformat and now work like a charm
  8. #8
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    Reformat the card to Fat32
  9. #9
    4721
    May 2010
    florida
    10
    I'd also make sure the video is encoded in a format that can be used by the ipad. I've used SDHC via the camera kit without a problem. I did have an issue with a Micro SD but got it to work after a couple of tries (I didn't have the micro pushed in far enough).
  10. #10
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    Calling apple won't get you anywhere. You need to format the sdcard as fat32 and clear everything on it off. Even if it is empty reformat the sdcard many cards need to be reformatedbefor they work with some devices.
    If that doesn't work take the sdcardback and get a different brand.
Sponsors
  1. Camera Connection Kit for USB audio
    By Seadog in forum iPad General Discussions
    Last Post: 10-03-2011, 04:21 PM
  2. iPad camera connection kit
    By Sincere11105 in forum iPad Reviews
    Last Post: 07-11-2010, 02:14 PM
  3. Camera connection kit...
    By Wetstuff in forum iPad Accessories
    Last Post: 05-21-2010, 01:41 PM
  4. Camera Connection Kit
    By Gayle in forum iPad Accessories
    Last Post: 04-02-2010, 10:39 AM
  5. No USB/Camera Connection Kit
    By SCHMEGGA in forum iPad Accessories
    Last Post: 03-18-2010, 02:26 PM
camera connection kit not supported
format sd card for ipad
how to format sd card for ipad
ipad 2 camera connection kit doesn't work
ipad 2 sdhc
ipad camera connection kit documentation
ipad camera connection kit does not work
ipad camera connection kit doesn't work
ipad camera connection kit not supported
ipad camera connection kit sdhc
ipad camera connection kit troubleshooting
ipad camera connection kit won't work
ipad camera connection troubleshooting
ipad camera kit troubleshooting
ipad sd card format
ipad sd card reader doesn't work
ipad sdhc
my ipad camera connection kit won't work
sdhc ipad
troubleshoot ipad camera connection kit
