My ipad2 looses battery time even when its not in use and switched off.Is this normal?
This is a discussion on battery life within the iPad Help forums, part of the Apple iPad Discussions category; My ipad2 looses battery time even when its not in use and switched off.Is this normal?...
Have a look here..
Ipad battery drop overnight
Do you have alarms set? Alarms work (at least on the phone) even when the iPad(iPhone) is turned off. So it could be listening or checking the time. Not sure how it works.
64GB 3G White iPad
I pad is great things in this busy life. There are many type of ipad available in markets. As well as many useful parts in this ipad. Battery is most important part in i pad. Generally I pad battery use to around 10 hours.
