Results 1 to 10 of 12
    70518
    Jun 2011
    9
    Problem with sound
    Hi everyone I have a question would like to know how to fix the sound on my NEW iPad 2. I haven't had it even 3 months and already the sound has gone out. Please let me know what I can do. I hit the reset/restart button 3 times & refreshed it all out of ideas. PLEASE SOMEONE WITH TECHO SKILLS HELP. THANK YOU
    iPad Junkie!
    66771
    Jun 2011
    Arizona
    175
    Well, I haven't decided if I'm a fan or not but I sure like it thus far! Anyway, welcome to the money pit hobby of mobile madness.
    Dan
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    Have you lost all sound, or just some sounds?
    Double check you did not slide the mute switch on the side of the iPad.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    70518
    Jun 2011
    9
    Thanks SaberOne didn't feel like much of a fan a few hours ago either. I had a sound issue with my BRAND NEW iPad 2. I thought I haven't had this thing even 3 months and all ready it's giving me the blues. However, I found a solution to my problem while researching a solution. Anyone out there with a sound problem with your Apps or the keyboard clicking sound this is how you fix it. Hit your home key at the bottom of your iPad TWICE. After you do that you should see a bar/dock appear for easy access to other apps. Scroll to the left and where your iPod settings are look for the sound picture hit it to make sure it is not on mute (like mine was) :-) THERE YOU HAVE IT. I hope this helps anyone with this problem. Enjoy your iPads guys
    70518
    Jun 2011
    9
    Quote Originally Posted by f4780y
    Thanks f4780y for the assistance I just found the solution  Wondering though the iPad 2 doesn't have a mute switch on the side does it only the sound button for volume adjustments right.
    37823
    537 times
    Cranbrook, Kent, UK
    15,666
    Quote Originally Posted by Kaff
    That button can either lock rotation of the screen or mute the sound depending on how it is set in settings Settings >> General >> Set Side Switch To
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    You can change what the switch does between rotation lock and mute in the Settings app. Many folk change this then forget and slide the switch.... If you change the setting, the soft key you pressed to mute becomes the rotation lock key...
    70518
    Jun 2011
    9
    Didn't know you could do that thanks for the info. 
    70518
    Jun 2011
    9
    Quote Originally Posted by Gabriel1
    Thanks Gabriel for the heads up learning new things everyday with this. ,"k
    Kl
    Ki
    iPad Junkie!
    66771
    Jun 2011
    Arizona
    175
    It's been my experience with anything tech' that most issues are easily solved in settings. Especially if something goes weird following an update or resource install.
    Dan
  1. Hello fellow iPad fans
    By CurryAssassin in forum New Member Introductions - Site Assistance
    Last Post: 04-30-2011, 07:47 AM
  2. Hello iPad fans
    By Grateful11 in forum New Member Introductions - Site Assistance
    Last Post: 01-25-2011, 08:50 AM
  3. Gorillaz Thank Fans With Free iPad Album on Christmas Day
    By xune in forum iPad General Discussions
    Last Post: 12-27-2010, 12:55 PM
  4. Hello to iPad Fans
    By BluAzn in forum New Member Introductions - Site Assistance
    Last Post: 07-08-2010, 06:24 AM
  5. Hi Ipad Fans :)
    By Lauro in forum New Member Introductions - Site Assistance
    Last Post: 05-29-2010, 12:20 PM
ipad 3 troubleshooting sound
ipad doesn't have sound
ipad doesn't make sounds
ipad troubleshooting sound
my ipad 2 won't make sounds
my ipad doesn't have any sound
my ipad doesn't have sound
my ipad doesn't make sounds
why doesn't my ipad have sound
why doesn't my ipad make noise
why doesn't my ipad make sounds
why my ipad doesn't have sound
