Caps?
This is a discussion on Caps? within the iPad Help forums, part of the Apple iPad Discussions category; Caps key won't stay set after pressing it twice. Is there some other trick ? Maybe I missed something. DUH??????? Sent from my iPad using ...
Results 1 to 10 of 11
Like Tree2Likes
Thread: Caps?
    46091
    OMAHA NE
    76
    Caps?
    60393
    May 2011
    Kuala Lumpur, Malaysia
    565
    Quote Originally Posted by DICKNPHYL
    Go to Settings, then General, then Keyboard. Make sure Enable Caps Lock is switched to on. Other than that, I got nothing.
    - Sent from my BRAND-NEW iPad 2!
    Proud owner of a black 64GB Wi-Fi +3G iPad 2
    Ex-owner of a 32GB iPhone 3GS
    (R.I.P. 04/2009 - 01/2011)
    46091
    OMAHA NE
    76
    Khaid---I CID. The settings and they were okay as you suggested. Did't work. For now I guess you just can't lock caps on.
    Thanks-- DICKSTER-------
    116 times
    15,249
    Quote Originally Posted by DICKNPHYL View Post
    41617
    Belgium
    74
    IF I CLICK THE TWO SHIFT BUTTONS AT THE SAME TIME, MY CAPS ARE LOCKED. OOPS .... Unlocking now.
    46091
    OMAHA NE
    76
    Smile Caps lock-so simple
    Clicking both shift keys does the trick as you can see this typing--so simple--thanks for the hint !
    Dickster---------
    41617
    Belgium
    74
    Dickster---------
    Y welcome
    29533
    Texas
    19
    Finally!
    I can't believe I've missed this "settings/Keyboard/caps lock ON" thing... It's been 18 LONG months! :P
    BUT NOW I CAN TYPE IN CAPS LOCK AAAALLLLL I WANT, LA LA LA... HAHA. THANKS Y'ALL!
    39716
    12 times
    Santa Barbara, CA
    206
    Thanks for the tip and the chuckle! Such FUN!
    Never, never, never give up -- Winston Churchill
    baanestad likes this.
    Bark less, wag more.
    iPad Ninja
    32446
    22 times
    Feb 2011
    Australia
    1,626
    Just great
    Greetings from paradise,on my iPad
  1. Caps lock
    By sjleworthy in forum iPad 2 Forum
    Last Post: 04-19-2011, 07:27 AM
  2. ShowCase Tweak Enables Your Keyboard To Show CAPS
    Last Post: 02-14-2011, 12:50 AM
  3. caps lock
    By mrdinh in forum iPad Help
    Last Post: 07-09-2010, 10:06 PM
cap key on ne ipad
caps lock won't work ]on ipad 4
capslock on ipod won't work
how make ipod caps to stay on
how to make caps button stay on on iphone
how to make caps lock stay on iphone5
iphone 4 won't caps lock
iphone4s won't stay in caps
make caps button stay on iphone
make ipad caps lock stay on all the time
the caps on the ipod won't work
why wont ipod do caps lock
