keyboard does not work in go daddy's website tonight
This is a discussion on keyboard does not work in go daddy's website tonight within the iPad Help forums, part of the Apple iPad Discussions category; Is the ipad 2 compatible with this software....
Results 1 to 5 of 5
    57288
    May 2011
    matawan new jersey
    119 times
    15,248
    Quote Originally Posted by berrymark View Post
    Are you talking about the domain hosting website, godaddy.com? It works fine for me, no problems. What exact difficult were you having?
    57288
    May 2011
    matawan new jersey
    Yes the domain hosting website. When I try to tap on text box to change the wording the keyboard fails to pop up.
    119 times
    15,248
    57288
    May 2011
    matawan new jersey
    GO daddy's website has webhosting feature (using their "Page Designer feature)'.
    I created the site on a PC before I got my Ipad. I am unable to revise any of the webpages on go daddy that I created. (PS my friends can edit the wesite from their PC just like before).
    Anyone using go daddy with their iPad?
  1. Can I get my old Apple Bluetooth keyboard to work with iPad 2?
    By livfoss in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-14-2011, 02:20 PM
  2. Does Ipad1 keyboard dock work with Ipad2?
    By Gen from Oz in forum iPad 2 Forum
    Last Post: 03-09-2011, 06:05 PM
  3. Does your iPad work with this website??
    By PrahaExpat in forum iPad Help
    Last Post: 06-23-2010, 06:12 PM
  4. App Store App required for keyboard to work right?
    By LAC_STS in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-26-2010, 10:09 AM
  5. how to get The mouse and keyboard to work
    By johnny_chimpo in forum iPad Hacking
    Last Post: 05-13-2010, 12:18 PM
go daddy email keyboard problem
godaddy email keyboard problems
godaddy website tonight ipad
problem with go daddy email on ipad
website tonight on ipad
why does my keyboard not work on mygodaddy email
why won't website tonight not working
