novice music sync and i tune probs - pls help
This is a discussion on novice music sync and i tune probs - pls help within the iPad Help forums, part of the Apple iPad Discussions category; Hi sorry to bug you with what is likely to be basic stuff but - I've tried the step by step instructions and continue to ...
Results 1 to 1 of 1
    69564
    Jun 2011
    australia
    Hi sorry to bug you with what is likely to be basic stuff but - I've tried the step by step instructions and continue to have the same problems
    1. When loading i tunes from my computer's music library, everything is rearranged so that it is no longer in albumns etc but is now listed by artist and song - don't seem to be able to change the view.
    - Is it possible to retain the layout of my library in the transfer to i tunes
    - and then to i pad 2.
    2. Despite changing settings to 'only transfer songs and/or albums that are ticked' and also trying 'manage manually' the i pad2 attempts to sync the moment it is plugged in to the computer then fails because there are not enough gigs spare
    -How do I get around this problem
    Simply wish to copy music from computer library to i pad 2
    -How do I delete the music that has already managed to sync on to the i pad 2.
    thnx
  1. Can't get music to sync?
    By Motorbones in forum iPad Help
    Last Post: 05-11-2011, 09:15 AM
  2. IOS4.3 JB: battery drain & push probs
    By FastT in forum iPad Hacking
    Last Post: 03-23-2011, 06:04 AM
  3. iPod App does not show music after sync
    By ericmen in forum iPad Help
    Last Post: 12-09-2010, 09:15 AM
  4. Can't sync music from iPhone to iPad using iTunes
    By firmament in forum iPad Help
    Last Post: 09-23-2010, 02:58 PM
  5. Can't Sync My Music
    By Atlasman in forum Off-Topic
    Last Post: 07-15-2010, 05:50 AM
how do i transfer i tunes from pc to i pad2
