Incorrect Wep Key? Drops Network?
This is a discussion on Incorrect Wep Key? Drops Network? within the iPad Help forums, part of the Apple iPad Discussions category; Ok so ill connect to my wireless router, then ill have a great connection as I am 5-8 feet from my router. I will then ...
Results 1 to 5 of 5
    3505
    May 2010
    7
    Ok so ill connect to my wireless router, then ill have a great connection as I am 5-8 feet from my router. I will then spontaneously lose the connection and it will say incorrect password or wep key or w/e.
    Has anyone seen this problem or know how to fix it?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Is it a dual band router? Some people have hade issues with them.
    Could also be your router dying.
    3505
    May 2010
    7
    would not be be the router dying as my laptops do not have any problems with it. Yes it is a b/g
    iPad Ninja
    3495
    27 times
    May 2010
    Switzerland
    2,017
    This topic comes up SO many times, and I've heard every guess from router dying to being the fault of the Windows PC. :sigh:
    It is a CONFIRMED bug that Apple has stated they will fix, and give advice how to work around here:
    iPad: Issues connecting to Wi-Fi networks
    5761
    Jun 2010
    Pittsburgh
    I'm running in to the same problem.
    So received my iPad in the mail after a 2 week wait I have the 64 3G model. I connected my verizon fios router to it with the version set up password. I have a Mac book, my iPhone, a windows pc, and a wifi printer. For all of them I have had no connectivity issues. The iPad asked for the password to connect and within about 10 minuets it asked for the password again. So I would go to an app that requires web access and it would not load so I would have to go back to safari to reconnect. So after running in to the problem over and over I went through the apple suggestion for a fix. I changed for wep to wpa which, I had to call verizon to get the password for the router. The. Ice thing was I was able to pick my own password that was easy to remember. I then updated the password for all my other devices with the new password. Still no fix, so I called apple and the rep came to the conclusion that I had a bad iPad. I set up an appointment with the local apple store and they just ran a test and gave me a new iPad. So I'm typing on it at home today and after about an hour I have had 1 instance where it asked for the password again. I will update to let you all know if it was the iPad was bad or if was a bigger problem. The apple rep seemed to have a rash of this problem
  1. AT&T Network Restrictions
    By Sonny Burnett in forum iPad Carriers
    Last Post: 05-04-2010, 08:20 PM
  2. how do I get the at&t 3g network hooked up?
    By ipadgypsy in forum iPad General Discussions
    Last Post: 04-30-2010, 05:30 PM
  3. AT&T 3G network overseas
    By michaelruggeri in forum iPad Carriers
    Last Post: 04-20-2010, 02:54 PM
  4. Replies: 0
    Last Post: 04-18-2010, 08:43 PM
  5. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
change wep key ipad
how do i join a network on my mac after inputting an incorect password?
how to fix incorrect wep key
incorrect wep key
ipad wep
ipad wep incorrect password
ipad wep key
wep key incorrect
wep key ipad
wep with incorrect password
wrong wep key entered
wrong wep key router
