Ipad drops wifi connection
This is a discussion on Ipad drops wifi connection within the iPad Help forums, part of the Apple iPad Discussions category; I've been having this problem too. Googled it and 1 suggestion said this happens to some people after they have done a software update? Solution ...
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 29
  1. #11
    68566
    Jun 2011
    Brisbane, Australia
    8
    I've been having this problem too. Googled it and 1 suggestion said this happens to some people after they have done a software update? Solution was to go to settings, wi fi, select the relevant network and use "forget this network". After it removes the info then proceed to re-recognise the network. Apparently it has fixed the problem for some people. Am yet to try it - trying to locate the password/code I need! Let me know if it helps anyone please!
  3. #12
    iPad Enthusiast!
    65992
    Jun 2011
    36
    I'm not sure about credit card information in setting cellular data will help you connect to the internet because there is not such thing in the cellular data.
    1. Try to test your wifil connection in Settings/Wifi
    2. Ask your 3G service for setting information with 3G.
  4. #13
    71657
    Jun 2011
    Mine does this constantly and is driving me nuts! Normally, after it drops, it will bring up the available networks within range and I can choose my wifi and it reconnects with no problem. But sometimes it will ask me to reenter my wep password. This really was a problem since it's a fairly long pw. I figured out a shortcut in case anyone else is having this prob. Using notepad type in your wep pw and then copy it using the highlight function. Now every time it asks me to reenter the pw I simply tap once on the line and use the paste function. I just rebooted my iPad and it still had the pw copied. So this is what I do until apple fixes this.
  5. #14
    72243
    Jul 2011
    Madrid Spain
    Wink iPad 2 (64/3G) drops wifi
    I too had the same problem. An amigo here in Madrid told me to try to reset all settings. I did this by going into settings (general) and at bottom hit the reset for all settings. Worked like a champ...he said that he had similar problems with his iPhone and an apple employee told him that it could be induced by an application that failed to load properly..??...FYI ... He said this procedure fixed his brand new iPhone 4 as well for not charging properly ....
  6. #15
    42499
    Georgia
    12
    If you reset do you lose everything? Apps, email, etc.
  7. #16
    72243
    Jul 2011
    Madrid Spain
    Nope.......
    Cheers!
  8. #17
    Owl
    Owl is offline
    63733
    Jun 2011
    The Great Tree
    24
    Quote Originally Posted by gplain58 View Post
    This worked for me. Thank you, gplain!
    64GB WiFi White iPad 2 ~ Oberon Creekbed Maple cover
  9. #18
    71657
    Jun 2011
    I reset my IPAD2 as instructed above and I can verify that I did not lose any data. So far so good for holding the wifi. Thx!
  10. #19
    76054
    Jul 2011
    17
    I have recently had to have a replacement iPad 2 and I have been experiencing some problems with the wifi dropping out. I have reset all settings and so far so good, however if it does it again, then I will consider resorting it.
    Not too happy though, I have been a a happy iPad user since the start ! And hope to be untill the bitter end!
    Thanks in advance for replying to my post
    Dan Thomas
  11. #20
    76047
    Jul 2011
    New delhi
    I have the same problem. Once it is switched off. I can not access wi fi. Then I choose forget this connection in settings and re enter key, only then it works
  1. Replies: 50
    Last Post: 10-12-2012, 10:42 PM
  2. iPad 2 wifi connection drops intermittently....problem solved
    By Appsolutecreations in forum iPad General Discussions
    Last Post: 11-08-2011, 08:46 AM
  3. Replies: 3
    Last Post: 06-04-2011, 08:16 AM
  4. Replies: 3
  5. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
ipad drops internet connection
ipad drops off network
ipad drops wifi
ipad drops wifi connection
ipad loses wifi connection fix
ipad wifi keeps dropping
why do i have to keep renewing lease on ipad
why does ipad drop wifi
why does my ipad drop the internet
why does my ipad drop the wifi connection
why does my ipad drop wifi
why does my ipad drop wifi connection
