ibook crashes as soon as it loads. solutions?
This is a discussion on ibook issue within the iPad Help forums, part of the Apple iPad Discussions category; ibook crashes as soon as it loads. solutions?...
Good to hear from you. You’ll find a whole bunch of iPad enthusiasts in this Forum who are only too willing to help other iPad owners and to hear of their experiences. Don’t be afraid to post any questions you may have or use the ‘Search’ button near the top of the Forum web page. I usually find I discover one new interesting and useful piece of information about my iPad every day - and often not even what I was looking for!!
Hope to hear from you soon with your thoughts about the iPad.
Have fun and enjoy your iPad
If you don’t already have it you can download a copy of the iPad manual for free.
Apple - Support - Manuals
Please read the rules too!!
Hi Tim, I hope you can help me solve my ibook app problem here, the ibook app is not displayed in itune under the file sharing anymore, so I can't transfer my pdf file anymore, do you have any suggestion for that?
Thank you.
You have jailbroken your device with redsnow for the IOS 4.3.5 ? I think you have the same problem as me, theres a topic in the jailbreak session of this site.
There isnt yet any solution for this bug!
