Results 1 to 2 of 2
    65509
    Jun 2011
    Exclamation Help! Syncing Mail on iPad with iMac
    There has to be a solution to this!
    Basically I have a Rogers Yahoo account which is synched to my Desktop's Mail - I have programmed my iPad to also synch to the Rogers account however the program is there isn't a connection between my desktop and iPad. Yesterday for example, I replied to over 20 emails on my iPad and when I came home I had to manually delete or file them on my Desktop. I want a solution or an app so that when my iPad connects to the mail on my desktop.
    Please help,
    thanks!
    Rachael
    623 times
    Dayton, WA
    13,312
    This is how POP accounts work. I'm not sure how the Yahoo account works on the iPad is set up. Sometimes it acts like IMAP, and sometimes POP. However Yahoo only offers POP accounts for desktop clients.
    Here is the difference. POP accounts simply download email from the server. They can be set up to leave it there, or delete it on download. You can also tell it to delete the email when it is deleted on the client. What will not happen is for the server to tell the client to delete an email.
    IMAP accounts do everything on the sever. If you delete an email on one client, it is immediately removed from the server. Because the other clients are always kept in sync with the server they update immediately also (or as soon as they connect again).
    So here are the two things that might be happening. You Desktop automatically downloads the email throughout the day. Yahoo acting as an IMAP account faithfully deletes each email from the server, but because the emails are already on the desktop, they stay there. POP has no way to tell the desktop to delete mail.
    Or, Yahoo acts as a POP account set up to leave mail on the server which for a secondary and mobile client is usually the safest bet. After all, if you delete an email permanently on a mobile device using POP, that mobile device contains the only copy, in Trash. Not the most convenient place to try and recover stuff from.
    Then the desktop accesses the server when you get home, and downloads the emails again, because the device, prudently, left them there.
    Either way there isn't a lot you can do about it. There are no settings on the iPad you can make to change it's behavior.
    If the second scenario is what is happening though, you can chose to go to your Yahoo Mail in Safari on the iPad. Since your actions there delete email directly on the server the desktop can not download it later.
    If the first scenario is true, close your email client on the desktop before leaving home so that it can not update while you are gone.
    Or, go to your email on both the desktop and iPad using a browser. That way you are changing everything in the same place, on the server. You may have to revert back to the Mail app when dealing with some attachments.
  1. iPad to iMac
    By Tfstairs in forum iPad General Discussions
    Last Post: 05-09-2011, 08:55 PM
  2. Can I back up notes without syncing to a mail program?
    By dragon499 in forum iPad General Discussions
    Last Post: 04-27-2011, 08:17 PM
  3. Syncing Contacts from IMac to IPad.
    By jdangius in forum iPad Help
    Last Post: 04-09-2011, 10:48 PM
  4. Help moving iPad from old PC to new iMac
    By INGunGuy in forum iPad Help
    Last Post: 01-08-2011, 01:16 AM
  5. Syncing mail on Ipad
    By alex.swann in forum iPad Help
    Last Post: 06-17-2010, 04:07 AM
can get mail on ipad but not on imac
can i synch mail rules from imac to ipad
delete email ipad but not imac
how do i link mail between ipad and imac
how do i sync mail between imac and ipad
how to delete emails to ipad from imac
how to sync email between ipad and imac
should my mail sync on my ipad and imac
synch email imac
syncing gmail in imac and ipad
syncing ipad deletes yahoo mail on imac
why does yahoo mail not sync imac and iphone
