ITunes Sync Problem
This is a discussion on ITunes Sync Problem within the iPad Help forums, part of the Apple iPad Discussions category; Just started with new IPad. Updated ITunes version of Win XP machine - Itunes can see the IPad - but shortly after 'Sync in Progress' ...
Results 1 to 5 of 5
    4653
    May 2010
    USA
    ITunes Sync Problem
    Just started with new IPad. Updated ITunes version of Win XP machine - Itunes can see the IPad - but shortly after 'Sync in Progress' shows on IPad - ITunes displays MessageBox with 'Itunes could copy xxxx to Ipad because an unknown error occurred [-20] - after Ok another MessageBox with 'the Ipad cannot be synced - an error occured while writing to the device.
    Any ideas what might be wrong ?
  2. #2
    4653
    May 2010
    USA
    CA Internest Suite is Problem
    After a number of calls to some wonderful support at Apple - have narrowed down to the 'Personal Firewall' in CA Internet Suite I use. Workaround is to uninstall Firewall before Itunes/IPad sync
  3. #3
    iPad Master!
    2051
    2 times
    Apr 2010
    home
    1,353
    One of many reasons I do not use "firewalls" and virus"protection".... Besides slowing a computer down, they cause untold problems/conflicts on a system.
    Bremen Cole
    iPad 1st Gen 16G
  4. #4
    16022
    Sep 2010
    US - NY
    I have several voice memos (5) that are saved in my itunes. They play fine on my mac. But when I sync them on my ipad and ipod, the titles are there, but the content is missing. . . . in one case the device (both ipad and ipod) just skips to the next item in the library, on a second voice memo, it is playing the wrong memo . . . I have deleted the voice memos from itunes and re-copied them over from itunes library . . . but the problem persists.
    Can anyone help? I just don't get the pointer system itunes uses.
  5. #5
    iPad Guru
    1284
    4 times
    Mar 2010
    2,624
    Quote Originally Posted by Tech-Challenged View Post
    grab vlc and sync them to there....it should be able to play just about any format. And its free.
Sponsors
  1. Itunes Sync Issues
    By dbenning in forum iPad Help
    Last Post: 09-12-2010, 12:10 PM
  2. Copilot HD APP problem
    By Star56 in forum iPad Apps
    Last Post: 08-16-2010, 05:29 PM
  3. Replies: 2
    Last Post: 05-13-2010, 02:06 AM
  4. Replies: 6
    Last Post: 04-22-2010, 12:01 PM
  5. Itunes problem
    By Sincere11105 in forum iPad General Discussions
    Last Post: 04-09-2010, 08:23 AM
an internal device error occurred ipod
cannot sync ipad
internal device error ipad
internal device error ipad cannot synced
ipad cannot be synced
ipad cannot be synced an internal device error occured
ipad cannot be synced internal device error
ipad cannot be synched
ipad cannot sync
ipad cannot sync internal device error
ipad internal device error
ipad internal device error occurred
ipad sync error -39
ipad sync voice memos
iphone internal device error occurred cannot synced
ipod could not be synced an internal device error occurred
ipod sync internal error
sync voice memos to ipad
the iphone cannot be synced an internal error occurred
Tags for this Thread
