When ever I try and use the video on my ipad 2 I get this high contrast camera glitch. Basically areas where there is lots of light, it gets replaced by blackness...
Software or hardware issue??
Anyone else had this problem?
This is a discussion on High contrast camera glitch within the iPad Help forums, part of the Apple iPad Discussions category; When ever I try and use the video on my ipad 2 I get this high contrast camera glitch. Basically areas where there is lots ...
Try a restart, and if that does not work a reset. This has cleared up camera issues before.
Hey thanks...
It seams to have worked !! ...Lets hope it doesn't happen again!!![]()
No problem. Just like any other computer the iPad needs to be restarted now and then. Apple recommends once a week.
