Until today I have been able to get my email and calendar info to push to my iPad. It is working on my iPhone just fine. Anyone have any ideas?
Welcome to the forum, it will help if you identify the problem you are having a little more and what are you using on exchange (google)
iFrog - Sent from my iPad2 using iPF
iFrog - Ernie
iPad Forums Moderation Team
iMac 27" mid 2011 i7 3.4GHz, 16GB Ram, 2TB HD and 1GB Video Card
iPhone 4S Black 32Gb - iOS 6.0.1 - iPad Mini Black 64GB Wifi - iOS 6.0.1
Forum Rules. Please Read - Hacking Section Rules
I have microsoft exchange set up for reading my outlook email and using my outlook calendar. Last night everything was working fine and today it can't connect. It's working fine on my iPhone but not the iPad. I'm not sure what to do. Thanks!
Restart the iPad: Hold down the power button until the power off slider appears. Slide it off. When the iPad finishes shutting down, hold down the power button again until the Apple logo appears.
If that does not work try a Reset: Hold down the power and home buttons until the Apple logo appears. The iPad will reboot. This usually takes a bit longer than a restart.
If neither works, make sure you know what your account settings are, then delete and re-add the account on the iPad. All information is stored on the servers, so don't worry about losing anything on the iPad.
