iPad won't load apps.
This is a discussion on iPad won't load apps. within the iPad Help forums, part of the Apple iPad Discussions category; Threw some new books on the wife's iPad yesterday and updated to the current version of the software. No apps load now. Just wondering if ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    68182
    Jun 2011
    8
    Threw some new books on the wife's iPad yesterday and updated to the current version of the software. No apps load now. Just wondering if anyone has any ideas. Tried rebooting/resetting it. Only thing I can think of now it to do a factory reset. Thanks in advance.
    119 times
    15,248
    Quote Originally Posted by dsz071 View Post
    What exactly happens when you try to load an app - you touch the icon of the app on the iPad's Home screen; does anything at all happen? Is it the same for all apps - in particular I'm wondering about the iPad's 'stock' apps, such as Safari, Mail, Notes etc. If you have any folders containing apps can you open those folders?
    When you open the multi-task bar (double tap the Home button) are any apps running? Can you close these apps (press and hold any icon until they jiggle, then press the 'X' in the top left-hand side of the app to close it)? When they've been closed, will they open successfully then?
    68182
    Jun 2011
    8
    Stock apps are working just fine. When I try to open anything else, the app opens for about a half a second then closes.
    119 times
    15,248
    Did you try closing them in the multi-task bar? This is a common problem that Members seem to face when upgrading - not sure why but several have reported it. But closing the apps in the multi-task bar has worked on several occasions. You say you've already tried switching the iPad completely off and then on again - rather than just putting it to sleep - so that's one possible 'solution' out of the way, but closing the apps has worked OK for most people.
    If you don't have too many apps, deleting and re-installing the apps is another way forward but if you're one of those people who have a large number of apps, then this won't be an attractive solution....
    68182
    Jun 2011
    8
    I honestly don't know where the multi task bar is... Like I said, wife's ipad. I just use it to read a book every now and then. She thinks I screwed something up when I updated the ipad.
    119 times
    15,248
    Nothing is screwed up - you just need to close all the apps using the multi-task bar.
    Double-tap the Home button and the top of the screen will slide upwards to reveal the multi-task bar at the bottom of the screen. There you'll see a row of icons that indicate the apps that are currently loaded. We need to close them all. Press and hold any one of the icons in the multi-task bar until they start to jiggle. Each icon will then have a 'X' symbol in its upper left hand corner. Press each 'X' and the corresponding apps will shut down completely. Do this for all the apps. Now touch the Home button and the multi-task bar will close.
    Now you're back to the regular Home screen and you can try and open an app again. You should find that they will work OK this time.
    68182
    Jun 2011
    8
    OK, now I'm fairly technologically efficient, but I'll be damned if I can find a Home button to double tap. I've looked countless times through each of the three side scrolling "pages" and I can't find it. If it's here and I'm just missing it, then I will proudly wear my dunce cap, but I can't see the damn Home button...
    119 times
    15,248
    The Home button is the button at the bottom of the iPad, just above the Dock connector.
    68182
    Jun 2011
    8
    That's what you were talking about. My bad, I was looking for an icon on the screen. Unreal. OK, just did that and nothing has changed. The apps still don't load.
    119 times
    15,248
    OK - so you went into the multi-task bar and manually closed all the apps.
    Then you went back to the Home screen and tried to open the apps and they just briefly open and then close.
    If you now open the multi-task bar again, is the app that you tried to open (and it then closed) showing in the multi-task bar? Of course, all the other apps that you closed should most definitely not be there (because you closed them) but I'm wondering whether the app that briefly opened is showing.
  1. Apps won't load
    By Christophe Francois in forum iPad Help
    Last Post: 01-09-2013, 01:19 PM
  2. My apps say waiting and wont load?
    By Shiny in forum iPad Help
    Last Post: 05-16-2012, 05:13 PM
  3. What will be your first (3) movies,apps & pictures you load?
    By Isaac Newton in forum iPad General Discussions
    Last Post: 01-20-2012, 08:04 PM
  4. How can I load my DVD movies on to the iPad?
    By JLStrange in forum iPad General Discussions
    Last Post: 08-23-2010, 08:22 PM
  5. How to load and view PDF on Ipad?
    By Pvanosta in forum iPad Help
    Last Post: 06-13-2010, 02:26 AM
app wont load on ipad
apps won't load on ipad
apps won't load to ipad
apps wont load on ipad
ipad apps won't load
ipad won't load apps
ipad wont load apps
my apps wont load on my ipad
