iPad won't load apps.
This is a discussion on iPad won't load apps. within the iPad Help forums, part of the Apple iPad Discussions category; Yes, the icon is there again. Tried to close it again and go back and open it and nothing....
Page 2 of 3 FirstFirst 1 2 3 LastLast
Results 11 to 20 of 21
  1. #11
    68182
    Jun 2011
    8
  3. #12
    119 times
    15,248
    OK - let's raise the stakes....a reboot....
    Press and hold at the same time the Home and Power buttons for a long time - could be as long as 20 seconds - until the white Apple logo appears. The iPad will then reboot. It takes a while, so have patience. When it's finished and you're back to the Home screen, try the apps again.
    Good Luck.
  4. #13
    68182
    Jun 2011
    8
    Nope, same thing... Apparently I need more than luck.
  5. #14
    119 times
    15,248
    OK - I need to think about this a little more. You've tried all the usual fixes.
    One last thing - try un-installing an app and then re-install it. To delete an app, hold down any icon on the Home screen until they all start to jiggle. Then press the 'X' in the top left hand corner. A message will appear asking you to confirm that you want to delete this app and all of its data. Then go to the App Store and re-install the app and see if the problem persists.
    You don't need to pay to re-install apps, but - in any case - try it with a free app, if you have any, or one you don't care too much about.
    If you don't have any like that, then try installing a new free app - anything - and see if the problem persists.
  6. #15
    66982
    Jun 2011
    7
    Nothing is screwed up - you just need to close all the apps using the multi-task bar.
    Double-tap the Home button and the top of the screen will slide upwards to reveal the multi-task bar at the bottom of the screen. There you'll see a row of icons that indicate the apps that are currently loaded. We need to close them all. Press and hold any one of the icons in the multi-task bar until they start to jiggle. Each icon will then have a 'X' symbol in its upper left hand corner. Press each 'X' and the corresponding apps will shut down completely. Do this for all the apps. Now touch the Home button and the multi-task bar will close.
    Now you're back to the regular Home screen and you can try and open an app again. You should find that they will work OK this time.
    Correspondingly, I got a '-' instead of 'X'. Is it the same?
  7. #16
    68182
    Jun 2011
    8
    That appears to have done the trick. I re-downloaded one app and it works fine, plus now all the other apps that were screwing up are working also. Thank you very much for your help. It is very much appreciated.
  8. #17
    119 times
    15,248
    Great news!! Sorry it took so long to get there....
  9. #18
    119 times
    15,248
    Quote Originally Posted by dabuglam View Post
    Yes - sorry, I was doing this from memory!
  10. #19
    74630
    Jul 2011
    I had this exact problem and fixed it. It seems to be an iTunes store problem related to "authorization" of an app on a particular machine. I tried all the above with no success, but found that I could download a new app and it worked. Shortly thereafter all the other apps were working again.
  11. #20
    75813
    Jul 2011
    I have been having the same problems, but after trying all the suggestions in this thread, nothing has worked for me
    Should I be resetting my ipad altogether?
    Cheers.
  1. Apps won't load
    By Christophe Francois in forum iPad Help
    Last Post: 01-09-2013, 01:19 PM
  2. My apps say waiting and wont load?
    By Shiny in forum iPad Help
    Last Post: 05-16-2012, 05:13 PM
  3. What will be your first (3) movies,apps & pictures you load?
    By Isaac Newton in forum iPad General Discussions
    Last Post: 01-20-2012, 08:04 PM
  4. How can I load my DVD movies on to the iPad?
    By JLStrange in forum iPad General Discussions
    Last Post: 08-23-2010, 08:22 PM
  5. How to load and view PDF on Ipad?
    By Pvanosta in forum iPad Help
    Last Post: 06-13-2010, 02:26 AM
app wont load on ipad
apps won't load on ipad
apps won't load to ipad
apps wont load on ipad
ipad apps won't load
ipad won't load apps
ipad wont load apps
my apps wont load on my ipad
