Charging my ipad 2 through my PC?
This is a discussion on Charging my ipad 2 through my PC? within the iPad Help forums, part of the Apple iPad Discussions category; Whenever I connect my ipad 2 to my PC, it says "not charging". Is there a way to get it to charge when hooked up ...
Results 1 to 10 of 12
    54340
    May 2011
    USA
    243
    Question Charging my ipad 2 through my PC?
    Is there a way to get it to charge when hooked up to my PC? Or does it need to be plugged into an outlet?
    7489
    126 times
    Jun 2010
    Sacramento, California
    14,962
    Typically, the computer is not powerful enough to charge our iPads. It states that it is NOT charging but really it is ~very very slowly.
    Is there a reason you prefer to charge this way as opposed via the wall socket?
    Marie ~
    Forum Rules. Please Read.
    appleforums.net
    26626
    20 times
    Dec 2010
    North Carolina - US
    1,545
    Quote Originally Posted by GAMESHARQ
    Computer will not charge the iPad because the USB will not have the power needed for the iPad to charge. The power adapter need to be 10 watts and the is no way that the pc can provide that.
    iFrog - Sent from my iPad2 using iPF
    iFrog - Ernie
    iPad Forums Moderation Team
    iMac 27" mid 2011 i7 3.4GHz, 16GB Ram, 2TB HD and 1GB Video Card
    iPhone 4S Black 32Gb - iOS 6.0.1 - iPad Mini Black 64GB Wifi - iOS 6.0.1
    Forum Rules. Please Read - Hacking Section Rules
    54340
    May 2011
    USA
    243
    Quote Originally Posted by SweetPoison View Post
    Sometimes I don't always have a wall socket within reach so it would be nice to charge it through a computer. I guess that's not an option though.
    36085
    13 times
    n/a
    477
    The iPad will charge, albeit slowly, from the computer as long as the screen is OFF. It will take roughly 4 times as long to charge via USB on the PC that it would using the wall charger.
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    It will depend on the available amperage in the USB port. Not all computer USB ports are created equal. If there is not enough power available it will not charge.
    -t
    36085
    13 times
    n/a
    477
    If there is current running through the cable, it will charge the battery. It will not do it fast, it will not do it while the screen is on, but it will charge.
    iPad Ninja
    62473
    62 times
    Jun 2011
    1,607
    Sorry, there is a minimum threshold for the charging circuit to operate so unless you exceed this level no charging will occur.
    The iPad will actually report that it is not charging when you plug it in if the circuit has not activated.
    -t
    70775
    Jun 2011
    The charging process is usually from input: 240V to Chargers ,then after chargers' changing, the current be flowed into our Ipad, however,if charge just through a usb cable,that's not enough ,as we know,the current is very few,at this hand,it 's not able to charge your ipad
    36085
    13 times
    n/a
    477
    It says Not Charging only when the screen is on. Yes, I know it is obvious. However, when the screen is off, I will bet an iPad you get a charge. I have since checked on my older laptop (HP Pavillion) and my MBP. The % battery went up while the screen was OFF. On my MBP, however, it charges with the screen on. If you don't get any charge, you are most likely using a netbook on battery itself, in which case it cuts all power where power isn't needed. Other than very very few (1-2%) of cases, you will get a charge when the power to the screen is turned off.
  1. Charging the ipad
    By Tassiecelt in forum iPad General Discussions
    Last Post: 05-16-2011, 10:44 AM
  2. Replies: 7
  3. ipad not charging
    By Matt cooper in forum New Member Introductions - Site Assistance
    Last Post: 02-11-2011, 10:42 PM
  4. iPad use while charging
    By dragon472 in forum Apple iPad Polls
    Last Post: 12-27-2010, 08:25 PM
  5. Charging my ipad with my pc
    By clarman in forum iPad General Discussions
    Last Post: 05-27-2010, 04:42 PM
can we charge ipad mini into pc
charge ipad sony vaio
how do i charge my ipad 2 from a computer
how do i charge my ipad2 on my laptop
how to charge ipad 2 from computer
how to charge my ipad2 on my computer
how to get my ipad charged on sony viao laptop
hp pavilion wont charge my ipad mini
ipad charging threshold
ipad not charging toshiba laptop
sony vaio not charging ipad
toshiba not charging ipad
