Hi,
All my apps switch from portrait to lanscape apart from mail. It sits in portrait mode whatever I do. All apps move from one to the other with no problem. I couldn't see a setting for this.
Any ideas please???
Thanks,
Wendy
Hi,
Any ideas please???
Thanks,
Wendy
Tim,
Not only do I love you because you fixed my mail problem with solution 1, but I also love you because you are from Scotland
I'm thinking of the Cairngorms right now![]()
Cheers Tim!
