That same old problem
This is a discussion on That same old problem within the iPad Help forums, part of the Apple iPad Discussions category; Hi, i've been following the forum for a while, having had my iPad for a few months, so I know this is a common problem ...
Results 1 to 8 of 8
    67173
    Jun 2011
    11
    Hi, i've been following the forum for a while, having had my iPad for a few months, so I know this is a common problem but I can't find the answer.
    Briefly I want to delete photos that I put on my iPad via iTunes.
    I have removed the photo folder from my pc as I think that is what I must do
    When I connect to iTunes on my pc it starts to sync . I click on Photos at top, and select All folders but when I select Apply at the bottom I get a message saying : Are you sure you want to remove 24 apps from IPad. This will delete these apps and data from the iPad. The choice is Remove or Cancel. I don't want to lose my apps. But selecting Cancel puts an end to my removing or adding more photos.
    Please can you help. Many thanks.
    119 times
    15,248
    I have moved your post to the Help section, where I think it will receive better attention..
    Welcome to the Forum
    13576
    1460 times
    Aug 2010
    Western NY state (USA)
    11,075
    What it appears you might have to do is move your app data/settings over to iTunes, then do the photo sync. Try this:
    Connect the iPad and when it shows in iTunes, right click on your iPad line in the leftmost column of iTunes. Select "Transfer Purchases." This'll move all the apps/info you have on your iPad to iTunes and update the apps portion of your iTunes to reflect the apps on your iPad (they'll be checked under the Apps heading at the top).
    Once you've transferred your purchases, then try the photo sync step again. Hopefully, it won't tell you that you are trying to delete 24 apps from your iPad.
    Hope that helps.
    P.S. Even if you delete apps from your iPad, you can still use iTunes to put them back on (or re-download them from the App Store). Once they're bought, you don't have to buy them again.
    67173
    Jun 2011
    11
    Quote Originally Posted by Mickey330
    Hope that helps.
    Hi
    Many thanks for your advice. I gave it ago this morning, but unfortunately when I try to sync my photos, the same message about losing the apps appears.
    It's frustrating as I would prefer not to lose and then reinstall my apps, and at the moment I can neither delete or upload my photos onto the iPad.
    Best wishes.
    13576
    1460 times
    Aug 2010
    11,075
    Sorry that didn't work. That's all I know how/what to do because I don't use iTunes to sync/manage my photos.
    My recommendation? Maybe you should go ahead and do the sync/reinstall apps once - just to be done with it. Then, go to the App Store and get a photo manager app that will let you copy/paste/sync/transfer photos to/from the iPad.
    I use Photo-Sort, which yeah, it's a paid app ($1.99 USD), but it works well. Plus, it has an FTP function which allows you to load a folder onto your PC so you can easily transfer photos back and forth. You can delete photos on the iPad or save them to the Photo app for use with other iPad apps.
    I'm not trying to sell Photo-Sort, as there are plenty others out there. This is just the one I use because, to tell you the truth, using iTunes for anything other than storing my apps and holding a back-up scares me! Too many horror stories!
    Anyway. Sorry my idea didn't help. Good luck.
    P.S. If you do decide to go with a commercial photo management app (and thereby accept the fact you'll "lose" 24 apps on your iPad) - do a backup first! That way, you'll most likely have all the info from those apps saved and when you re-load them from the PC, you'll have them as they were before they were taken off.
    67173
    Jun 2011
    11
    Thank you. The photo sort app sounds a good option. I will do some research.
    I have deleted photos before using iTunes but that was before this awful message popped up. Don"t understand why it has appeared. I can't help wondering if it is something I have done or to do with ITunes itself.
    I may pay the Apple store in London a visit and see if they can come up with a reason for the message and a solution as how to get rid of it.
    Best wishes
    67173
    Jun 2011
    11
    Hi Mickey330
    I thought you might like to know that I have solved my problem. The message warning me I would delete my apps if I proceeded came about because somehow I had unchecked Sync Apps.
    I have no idea how that happened but once I checked SyncApps. I was able to delete the photos I didn't want and install the ones I did want.
    I'm new to iPad and still finding out what I can and can't do with it.
    Many thanks for your help. I still may get a photo transfer app as looking at YouTube videos they seem relatively easy to use.
    Best wishes
    13576
    1460 times
    Aug 2010
    11,075
    Super! Glad you got it sorted.
    And see? That's why I'm ascairt of iTunes! One little check mark missing and you're facing app deletion .... !
    Have [more?] fun learning about your iPad.
  1. HBO GO problem
    By Rafafito in forum iPad Help
    Last Post: 06-11-2011, 10:34 PM
  2. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  3. Problem????
    By David Vice in forum iPad General Discussions
    Last Post: 01-06-2011, 12:19 PM
  4. App problem
    By Coy886 in forum iPad Help
    Last Post: 12-02-2010, 01:14 PM
  5. problem with 3G!!!
    By bahram in forum iPad Help
    Last Post: 11-01-2010, 06:54 AM
hbo go some videos may not be available at this time
hbo go won't load ipad
hbo go won't load on ipad
hbo go won't open on ipad
hbo go wont load ipad
hbogo ipad some videos may not be available at this time
we're sorry. some videos may not be available at this time
we're sorry. some videos may not be available at this time :1010
Tags for this Thread
