Some of the sites I go to tells me I require flash. Does iPad have a fix for this?
Don
This is a discussion on Flash within the iPad Help forums, part of the Apple iPad Discussions category; Some of the sites I go to tells me I require flash. Does iPad have a fix for this? Thanks Don...
Don
Hi Don!
Ipad doesn't support flash, but there are apps that can be used. iSwifter, Puffin, to name a few. Check out the app store ~
Some think they are great, some state they any workaround is unpredictable and buggy.
Good Luck!
Does anyone know if Apple will include some form of flash in the next OS release this fall?Originally Posted by SweetPoison
Don
