Default Setting For Calendar?
This is a discussion on Default Setting For Calendar? within the iPad Help forums, part of the Apple iPad Discussions category; Is there a way to Calendar Events appear with your own preferred default options? For example, I like most of mine to remind me 2 ...
Results 1 to 2 of 2
    65679
    Jun 2011
    Is there a way to Calendar Events appear with your own preferred default options? For example, I like most of mine to remind me 2 days, and again 2 hours in advance of the event.
    580 times
    Dayton, WA
    13,191
    There is no way to do this in the Calendar app itself, however; if you sync with another calendar (say Google) you can set up to two alarms on the website, and they will sync non-default time/dates.
    Only two though. If you do three then the event won't sync. Very annoying, and a problem I butted my head against several times before I figured out what whas happening.
    BTW, If you do not currenlty sync your calendar, I recommend setting up a Google account to do so. it's a good safety net. No single device/compuer should ever hold all your critical information.
    If you set up the Google account on your iPad as an Exchangae account, you'll also be able to sync (and safeguard) your Contacts. Setting up Google Sync with your iOS device : Mail, Calendar, & Contacts - Google Mobile Help
  1. Setting default apps in iPad
    By dbaron44 in forum iPad Help
    Last Post: 04-19-2012, 04:09 AM
  2. Setting default ereader for ipad
    By Chark86 in forum iPad Help
    Last Post: 05-30-2011, 01:57 PM
  3. Setting alarm in Google Calendar
    By Brucie1dog in forum iPad General Discussions
    Last Post: 02-10-2011, 11:09 PM
  4. Default calendar
    By jhpb in forum iPad General Discussions
    Last Post: 10-02-2010, 06:42 AM
  5. Replies: 6
    Last Post: 05-29-2010, 09:23 AM
chang default calendar ipad
change default calendar ipad 2
how do i extend the alarm times on my ipad2 calendar?
how do i set ipad calendar default
how do you change the default start time on ipad calendar
how to increase default event time in ipad calendar
ipad 2 calendar default settings
ipad default calendar
ipad modify default event in calendar
setting a calendar as default on my ipad
setting default calendar ipad
