iPad outgoing email advice... It's set up, that's not the issue
This is a discussion on iPad outgoing email advice... It's set up, that's not the issue within the iPad Help forums, part of the Apple iPad Discussions category; Hey Guys - - Weird question probably. I have set up my outgoing email according what I've seen for Gmail. Which works great... I can ...
Results 1 to 4 of 4
    65503
    Jun 2011
    Hey Guys - -
    Weird question probably. I have set up my outgoing email according what I've seen for Gmail. Which works great... I can send emails and they show up at the destination.
    The problem is, I just want to use Gmail's outgoing server, I want to use my own email address. When I send email using Gmail's server, it comes up as if it came from my Gmail account and not my own domain email address.
    My domain doesn't have an outgoing email server.... On the iphone it's not an issue, it goes through cmwx.com or whatever it is... but with the iPad WiFi only.. I cant use that outgoing server....
    Any suggestions?
    iPad Enthusiast!
    63228
    Jun 2011
    Saudi Arabia
    60
    Just to be clear, did you go to: Settings>Mail>Add Account>Other>Filled in the Details?
    OS: Ubuntu 11.04
    iProducts: Original iPad (64G /3G) redsn0w rc15
    119 times
    15,248
    Quote Originally Posted by xpesrx View Post
    Hey Guys - -
    Any suggestions?
    I think I understand your problem. When you're using 3G on your iPhone the server lets you send email because it can authenticate your identity whereas, from the iPad using WiFi, it has no way of checking who you are. The so-called 'Port 25 relay' problem. Does your service provider support SSL and Port 465 authentication? I'm assuming the answer is probably 'no' and that's why you're using Gmail. I have the same problem with my service provider and have adopted the same solution and have the same problem! My workaround is to automatically forward all received Gmail to my service provider's email server - well, it's not really a workaround I guess. But, if you haven't done, it might be worth checking if your service provider supports authenticated email sending - then the problem goes away....
    65503
    Jun 2011
    Yes, Frost I've set up everything like you say here and it works...wroking/function isn't really the issue.....
    Yes Tim, that's exactly right...and I've done that too...for receiving mail.... the problem I have is that I want all mail to appear to come from my domain email address and not gmail....even though I used their outgoing server... normally I can just set the "reply to" or "description" settings to my domain email address.... but I dont see those options on the ipad... and my efforts to put it in the description of the POP section didnt help it at all
  1. Change Display Name in OutGoing Email
    By naman919 in forum iPad General Discussions
    Last Post: 09-19-2012, 05:15 AM
  2. Email problem - incoming and outgoing
    By csipke in forum iPad Help
    Last Post: 01-08-2012, 12:27 AM
  3. Replies: 11
    Last Post: 11-26-2011, 03:39 PM
  4. Outgoing email via iPad2
    By midren in forum iPad Help
    Last Post: 06-12-2011, 02:38 AM
  5. Outgoing email problems
    By Annemie in forum iPad Help
    Last Post: 05-28-2011, 12:13 PM
cmwx.com
ipower email on ipad
ipower email settings ipad
ipower email settings iphone
ipower iphone email settings
ipower mail for ipad
set outgoing mail on ipad
setting up ipower email iphone
