SDHC card reader woes
This is a discussion on SDHC card reader woes within the iPad Help forums, part of the Apple iPad Discussions category; I have a card reader kit that I purchased to transfer pictures by plugging my card into the adapter and into the slot I use ...
Results 1 to 2 of 2
    64051
    Jun 2011
    I have a card reader kit that I purchased to transfer pictures by plugging my card into the adapter and into the slot I use to charge my iPad. Worked fine until yesterday and now it does not seem to recognize the card. Any ideas would be appreciated
    Thanks in advance
    116 times
    15,249
  1. Suggestions on Business Card Reader?
    By MSaxatilus in forum iPad 2 Forum
    Last Post: 10-24-2012, 10:09 PM
  2. Square Up Credit Card Reader???
    By lonzom10 in forum iPad Apps
    Last Post: 08-22-2012, 06:33 PM
  3. USB / SD Card reader
    By jnr1963 in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-23-2011, 08:58 AM
  4. Camera kit SD card reader quit working
    By Rotorcraft in forum iPad Help
    Last Post: 03-13-2011, 01:18 AM
  5. Copy files from card reader to usb disk
    By atenzionefilms in forum iPad Help
    Last Post: 11-15-2010, 12:26 AM
can you use sdhc card in ipad
ipad 4 not recognizing hdsc card
ipad not recognize sd adapter
ipad sdhc card reader
ipad wont read sdhc
ipad wont recognise photos on my card
iphone sdhc card reader
my ipad wont read sdhc
sdhc card reader for ipad
sdhc card reader for ipad 2
sdhc card reader for ipad2
sdhc card reader ipad
