Help !
This is a discussion on Help ! within the iPad Help forums, part of the Apple iPad Discussions category; Hi I am a new user to Ipad and have purchased a lot of the ipad books etc still feel I am just not getting ...
Results 1 to 2 of 2
Thread: Help !
    63702
    Jun 2011
    Wicklow ireland
    Help !
    Hi I am a new user to Ipad and have purchased a lot of the ipad books etc still feel I am just not getting it . I need some help . I was using for email and surfing and now it cant find the server . Can anyone help me? Babs
    119 times
    15,248
