Help please, iPad 2 won't post on some forums
This is a discussion on Help please, iPad 2 won't post on some forums within the iPad Help forums, part of the Apple iPad Discussions category; Hello newbie here, help required. When I use one of my forums and I try to post a reply, the keyboard either fails to appear ...
Results 1 to 10 of 10
    63559
    Jun 2011
    Hello newbie here, help required. When I use one of my forums and I try to post a reply, the keyboard either fails to appear or it appears and immediately shuts down safari. Meaning I can't post on this particular forum. Is it a forum problem or an iPad problem? Thanks in advance
    116 times
    15,249
    63571
    Jun 2011
    liverpool
    I have the same problem! Thanks fot helping!
    63559
    Jun 2011
    Hi, thanks tried that and the problem still persists :-(
    116 times
    15,249
    Do you only have this 'shutting down' problem when trying to post on Forums or other websites, or does Safari shut down on other occasions? I'm suprised that resetting the iPad didn't fix the problem - it's a not-uncommon problem and powering down the iPad usually always works.
    So let us know if Safari shuts down on other occasions - i.e. it's a problem solely related to filling in forms etc....
    63559
    Jun 2011
    It only happens on one particular forum as soon as I tap in the reply box, Safari either shuts down immediately or the keypad pops up then safari shuts down
    579 times
    Dayton, WA
    13,187
    Check the setting (options) on the problem forum(s). Most will offer you a choice of text editors. The iPad has trouble with some of the WISIWYG editors. If you can change to another, do, and see if that works for you.
    63559
    Jun 2011
    There are no options to change. It works fine on my iphone4
    20755
    7 times
    Nov 2010
    Michigan
    436
    Do you have "accept cookies from visited" turned on in Safari Settings?
    579 times
    Dayton, WA
    13,187
    Well, you could check out the Tapatalk or Forum Runner apps and see if your forum(s) support one or the other. That would put an end to needing to go to the website for most tasks.
  1. Can't post in forums on the iPad??
    By foodie123 in forum iPad General Discussions
    Last Post: 09-21-2011, 08:06 PM
  2. Can't post bin lefora forums
    By Jtowne in forum iPad General Discussions
    Last Post: 05-22-2011, 06:36 PM
  3. Not able to post on some forums\message boards
    By Icepad in forum iPad Help
    Last Post: 05-12-2011, 12:29 PM
  4. New to Ipad forums!
    By Applebaum in forum New Member Introductions - Site Assistance
    Last Post: 03-27-2011, 10:38 PM
  5. Hello ipad forums
    By kraemder in forum New Member Introductions - Site Assistance
    Last Post: 10-11-2010, 05:22 AM
ipad 2 keyboard won't appear
ipad 2 won't show keyboard
ipad keyboard won't appear
ipad keyboard wont show up
ipad wont post
keyboard won't come up on ipad
keyboard won't pop up on ipad
lefora forum can't use ipad text box
my ipad wont post anything on facebook
my keyboard wont appear
my keyboard wont come up pn my ipad
why won't the keyboard on my ipad2 appear
