iPad 2 Apps not working, Help!
This is a discussion on iPad 2 Apps not working, Help! within the iPad Help forums, part of the Apple iPad Discussions category; I just upgraded to 4.3.3 and the latest iTunes and I did a full restore of my iPad as I upgraded but now all of ...
iPad Enthusiast!
I just upgraded to 4.3.3 and the latest iTunes and I did a full restore of my iPad as I upgraded but now all of the apps I downloaded wont open.
I get a quick flash of the app for less than a second, then it immediately cuts to black and goes back to the home screen. The apps are in the multitasking bar
However this is only with the apps, which I downloaded (Including the Apple ones like Pages).
I've searched various forums that have suggested soft reset, hard reset, reboot, restore and I've done all of these...numerous times!
Any help would be much appreciated!
06-08-2011 04:42 AM
OK - try this. Open the multi-task bar by double-tapping the Home button.
Press and hold any icon in the multitask bar until they start to jiggle.
The icons should have an 'X' in the top left hand corner.
Touch that 'X' to close each app - you have to do them one at a time - until none of the apps show in the multitask bar.
Touch the Home button to return to the Home screen.
Try opening the apps again and see if they work OK.
Good Luck
iPad Enthusiast!
Originally Posted by
Tim SPRACKLEN
Good Luck
Nope, no luck
Try the reset one more time, just in case.
Hold down the power and home button until the Apple logo appears (ignore power off slider if you see it). The iPad should reboot. Could take a while.
If that does not work you can try connecting it to iTunes on the Computer and Restoring it. Not from backup, just a restore. If that works (after testing the basic apps) you could try restoring from backup again and see what happens.
Before you do that, go into iTunes Preferences, the Devices tab, and turn off auto-sync. You'll want to do that so you don't accidentally backup the iPad after the first restore.Do not let the iPad sync in between the first restore and the restore from backup; otherwise there will be no backup to restore to latter.
If this does not work, or even before you try it if you prefer, call Apple Tech support. A reset should have fixed it. If a restore does not, then you are best off with the experts, if for no other reason than that they will probably walk you through these same steps before deciding you need your iPad replaced.
iPad Enthusiast!
Ok, Thanks - I'm going to call them up
I was going to get it replaced because of screen bleeding anyway but wanted to wait a bit so I could upgrade from 32GB wifi to 64GB 3G
Thanks, that worked for me! I hope this is not something I'll have to constantly do!
Apple only recommends the reset if you the iPad is unresponsive; however experience has show it sometimes help with other problems that a restart does not; and there have been not reports of it ever causing a problem.
You should rarely need to use a reset. It's often the last option before a restore. Here are a list of common fixes, including a reset. Typically you try them in the order listed; though if you've got general problem with all apps or the system you should start with the restart.
- You may not post replies
- You may not edit your posts
Forum Rules
By Tomvizzle in forum iPad Help
Last Post: 10-23-2011, 10:39 PM
By tmetcalf52 in forum iPad General Discussions
Last Post: 02-02-2011, 06:13 PM
By Big Texx in forum iPad Help
Last Post: 01-24-2011, 03:37 PM
By Phil_Rose in forum iPad Help
Last Post: 12-22-2010, 09:01 AM
By Dukins in forum iPad General Discussions
Last Post: 12-14-2010, 09:00 PM
apps not working ipad 2
apps not working on ipad 2
ipad 2 applications not working
ipad 2 apps not opening
ipad 2 apps not working
ipad 2 not working
ipad apps not responding
iphone apps not working on ipad 2
itunes app not working on ipad
my fitness pal app for ipad 2 quit responding
some ipad 3 apps not working
why do game not open on ipad
