I had to do a full system recovery on my PC...question about itunes
This is a discussion on I had to do a full system recovery on my PC...question about itunes within the iPad Help forums, part of the Apple iPad Discussions category; Long story short, I had to do a full system recovery on my PC and I had to reinstall itunes afterward. I opened itunes and ...
Results 1 to 2 of 2
    54340
    May 2011
    USA
    243
    Question I had to do a full system recovery on my PC...question about itunes
    I opened itunes and logged into my account but now there is no longer a section called "My Apps" on the left-side menu.
    I'm also afraid to connect my ipad because I don't want to to accidentally sync and remove all the apps from my ipad.
    How do I get all my apps back into itunes?
    41178
    Central Florida
    10
    Quote Originally Posted by GAMESHARQ View Post
    Long story short, I had to do a full system recovery on my PC and I had to reinstall Itunes afterward.
    I opened Itunes and logged into my account but now there is no longer a section called "My Apps" on the left-side menu.
    I'm also afraid to connect my Ipad because I don't want to to accidentally sync and remove all the apps from my Ipad.
    How do I get all my apps back into Itunes?
    Itunes can be tricky - I have two Iphone 4's, an Ipod, and two Ipads (ver 1 and 2). Usually Itunes is no problem.
    BUT, to be 100% safe, in your case, this is what I would do even though it will cost you a bit of time up front -
    Make sure you have the latest version of Itunes loaded and then sit down with your Ipad and manually LOAD each of your Apps into Itunes one by one (after you have selected "Applications" om the Itunes menu). Then check to see if there are any updates. When you are done, all your Apps should be back into Itunes. Then you can Sync with Itunes and reload all your "content" back onto your Ipad. Including stuff from Outlook, Photos, Songs, Pictures, E-Books, Podcasts, Etc
    But arent they already on the Ipad ????
  1. File System Question
    By kvozel in forum iPad 2 Forum
    Last Post: 05-01-2011, 04:47 PM
  2. iTunes Question
    By Knightoftheapp in forum iPad Help
    Last Post: 04-24-2011, 05:43 PM
  3. Replies: 5
    Last Post: 01-20-2011, 10:09 PM
  4. iTunes Question please!
    By SweetPoison in forum Off-Topic
    Last Post: 07-08-2010, 10:57 PM
  5. iPad file System question...
    By KillaBee in forum iPad Hacking
    Last Post: 07-01-2010, 06:39 PM
how do i reinstall itunes after i do a full restore of my computer
how to do a system restore on ipad
how to reload itunes after system change
iphone full system restore
itunes after sustem restore
itunes after system recovery
itunes and system recovery
itunes system recovery
reinstall itunes after system restore
reloading apps into itunes after reinstall
system recovery and itunes
tunes accound after system recovery
