Since using headphones I have lost sound on some apps? Any help appreciated!
This is a discussion on Speaker problem! within the iPad Help forums, part of the Apple iPad Discussions category; Since using headphones I have lost sound on some apps? Any help appreciated!...
Greatly appreciated - problem solved! Many thanks....
