Results 1 to 7 of 7
    62626
    Jun 2011
    north carolina
    HELP,ipad wont come on after 3 mos of being in the box.
    okay so i need help i bought my ipad brand new back in February i used it for about a month on and off and then it just got to the point where i didnt have time for it i played a few games and did this and that so i decide to put it up as i have a 2yr old and a 200lb st bernard and didnt want it getting damaged i kept it in the box turned off so it wouldnt get ruined and now i took it out today to play around with it and now it will not come back on???HELP i love my ipad ive just been so busy its sat in the closet..and id like to bring it back to life,any one have and advice on what i can do??
    thanks am
    62138
    Jun 2011
    Austin, TX
    Uhhh, have you tried charging it yet?
    116 times
    15,249
    34521
    Feb 2011
    91
    Even though you turned it off before putting it up the battery is probably completely drained. Plug it into the charger for at least a couple of hours and let the battery catch up.
    If it still won't turn on after that, get in tough with Apple CS.
    34521
    Feb 2011
    91
    Considering they can't get the iPad to turn on in the first place I don't think turning it off will help
    12657
    4 times
    Aug 2010
    Area DM51
    669
    For future reference, Li-Ion powered devices should be stored with the batteries at around 80% full. These batteries have a low self-discharge rate, and should easily last 3 months or longer of properly stored. Can you remember what the figure was when you stored it? And are you sure you powered it down completely?
    iPad Addict
    37720
    6 times
    Colonial Heights,Va
    1,395
    If charging it a few hours doesn't work, Apple should replace the battery under warranty. I'd be really surprised if they didn't.
    Support Our Troops!
    This post was Tapatalk approved
    Sent from wherever I'm at right now via my Apple tablet
  1. my ipad wont turn on
    By elush in forum iPad Hacking
    Last Post: 02-07-2011, 11:06 AM
  2. Help Ipad wont turn on
    By bdullea in forum iPad General Discussions
    Last Post: 01-31-2011, 08:13 PM
  3. ipad wont cut on!!!!
    By accordlayingkit in forum iPad General Discussions
    Last Post: 12-24-2010, 09:10 PM
  4. ipad wont turn on!
    By jbh19 in forum iPad Help
    Last Post: 11-23-2010, 06:24 PM
after. a long time off, ipad will. not power up
ipad 1 will not turn on after not being used for 3 months
ipad not turning on after long time
ipad not turning on after long time of not using
ipad not used for months
ipad will not turn on after long discharge
ipad wont turn off after long time off
ipad wont turn on after being left for months
ipad wont turn on after being off for a long time
ipad wont turn on after long time
ipad wont turn on after not using
ipad wont turn on after storage
